Disc Caliper Compatibility Question
Results 1 to 7 of 7
    Mar 2006
    I'm building up a road frame with IS disc mounts and would like to use the Ultegra R8020 groupset (with newest gen hydraulic discs). These disc calipers are flat mount, but in the product specifications, the Shimano website has the cryptic added comment "(available for IS mount with mount adapter)". I don't see any available flat-to-IS mount adapter from Shimano or anyone else. Does that comment mean there are substitute calipers that are IS-compatible or is there a flat-to-IS adapter that I haven't found?
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Mar 2006
    This is an adapter for a post caliper to flat mount frame. I'm looking for an adapter for a flat mount caliper to a IS mount frame. I don't think it exists but I don't understand the comment from Shimano in the original post.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by velojon View Post
    I've never seen or heard of such an adapter being made by anyone. Doesn't mean it doesn't exist, but I'd be very surprised.
    I.S. being before the heyday of discs, the stuff is too old to be "modern" and too new and inelegant to be "vintage" so it lands in the junkbin of unmaintained "standards" throughout history.
    That is a post-mount adapter. Not I.S.
    'brifter' is f'ing stupid
    Just checked QBP and they have nothing that will do that. The old IS taps stick out too far to use a flat mount caliper anyway...well, I'm 99% sure they do as I've never tried it since it's so far out of date.
    #promechaniclife
    Mar 2006
    Thanks all - consensus is that flat mount calipers will not go on an IS frame no how, no way. The best solution is to substitute in the Ultegra post mount calipers and put them on the IS frame with adapters.
    Jan 2005
    One thing to be wary of...in using post-mount with the new stuff, they changed which brake hose goes to the new R8000/9000 flat mount parts versus the post-mount that came before. They also use different inserts IIRC.
    https://docs.google.com/spreadsheets...29c/edit#gid=0
  1. DIsc Front Caliper Back?
    By MTT in forum Commuting, Touring and Ride Reports
    Last Post: 05-07-2010, 03:25 PM
  2. Brake lever/caliper compatibility question
    By drdiaboloco in forum Components, Wrenching
    Last Post: 04-27-2010, 11:54 AM
  3. Caliper Compatibility
    By velojon in forum Components, Wrenching
    Last Post: 11-25-2009, 01:18 PM
  4. mtn levers compatibility with caliper brakes?
    By opdeuce in forum Components, Wrenching
    Last Post: 01-18-2007, 11:55 AM
  5. Caliper size and fender compatibility
    By SadieKate in forum Retro-Classic
    Last Post: 11-26-2006, 01:57 AM
