Disk brake noise
Results 1 to 8 of 8
    Reputation: siclmn's Avatar
    Disk brake noise
    Has anybody ever tried a blob of "disk brake quiet" on the back of a pad in an attempt to quiet the squealing sound? It works on cars so why not on the bike. The only thing that worries me is that my brakes have a plastic membrane over the pistons and I don't want to compromise that by having it press on a blob of goo. All the bike mechanics that I have talked to say they have never heard of the stuff. When I hear that answer I immediately know that either they have never worked on cars or they just want to keep selling me another set of pads or a disk again.
    'brifter' is a lame word.
    I've heard of it. Never heard of it used on bicycle brake pads. Not sure I'd want to try it.
    I work for some bike racers
    and a bunch of skateboards
    Sep 2011
    I've tried it, the "red" brake quite spray one. Nope it didn't quite down the squeal. I'm guessing that it doesn't work on bicycle disc brakes because bicycle brake pads don't encounter the same vibration intensity as car ones do, so the spray doesn't work on bicycle. Bicycle brake squealing stems from different cause.
    PS: this forum should be changed to "Components, Wrenching, Braking" because soon braking questions will dominant this forum for shure!
    Apr 2011
    Apr 2013
    notice the noise when its wet out mostly. brakes work. just not a pleasant sound
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Most disc brakes will be noisy when wet. Nothing you can do about it. Been using disc brakes for years on my mountain bike. After any type of water crossing the brakes are noisy until they heat up and dry again.
    As far as using disc brake quiet for cars on bicycle brakes, try it but be very, very careful not to get it on the surface of the pads. It may change the resonance frequency (brake noise) to make it non existent or more bearable. I've used it before with mixed results.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Russian Troll Farmer
    Sep 2016
    I don't even use the stuff on my car calipers, and I've never had squeaky brakes, either. These work on the premise that a large gelatinous blob will reduce the vibrations, but good pads probably already have a certain amount of vibrational compliance built in.
    "L'enfer, c'est les autres"
    Reputation: jason124's Avatar
    Jul 2006
    You just have high performance brakes
    https://youtu.be/fUNHb9O52WQ
  1. Disk brake vs. Rim brake CX bike
    By ts8169 in forum Cyclocross
    Last Post: 07-19-2013, 10:56 AM
  2. Sram hydraulic disk brake levers?
    By 2ndPlace in forum Cyclocross
    Last Post: 12-06-2012, 06:58 PM
  3. Hydraulic TT brake rim not disk
    By QuattroCreep in forum Components, Wrenching
    Last Post: 01-20-2012, 01:03 PM
  4. Who makes 700c disk brake wheels?
    By texasdiver in forum Wheels and Tires
    Last Post: 06-01-2010, 11:50 AM
  5. Disk brake hubs or wheelsets?
    By crossracer in forum Cyclocross
    Last Post: 03-24-2007, 11:55 AM
