Do Tektro brakes suck?
Results 1 to 25 of 43
    pmf
    pmf is online now
    Seems like every "Shimnao equipped" bike I see on the web or the LBS has Tektro brakes. I see Nuevation charges $110 for Ultegra brakes over Tektro. That seems like alot, implying that these things are pretty cheap.
    Aug 2011
    Use the same pads on both and you probably won't even be able to tell the difference. Tektro make a wide range though, from cheap to expensive, so there could well be substantial differences in weight and materials, e.g. titanium vs steel.
    Sep 2011
    I actually found the worst thing about the tektro brakes I got on my bike to be the pads themselves. The brakes themselves are good but the pads were terrible.
    Mar 2006
    Quote Originally Posted by taralon View Post
    +1.... I have to agree with this.... Their pads suck. However, if you replace them with a pair of Kool Stop pads you'll be good to go and the Kool Stop pads really are an inexpensive upgrade.
    Reputation: JCavilia's Avatar
    Sep 2005
    By no means. Mechanically, even their inexpensive ones are fine for almost any use. But their pads are indeed lousy. Swap in some Koolstops and you have a perfectly functional brakeset. Their levers are fine, too, and a real bargain. BTW, Cane Creek levers are Tektros with prettier paint for more money.
    Sep 2011
    If it stops your bike it should be good enough.
    Jun 2007
    My wife's bike has some cheap no-name calipers (I believe they're tectros, but can't be sure), and the pads were pretty crummy and especially noisy. I swapped them out for some red Jagwire pads I had and they are 100% better all around, as good as my Ultegra calipers in performance. A really cheap and easy upgrade.
    Adventure Seeker
    Reputation: Peanya's Avatar
    Jun 2008
    I just put Tektro brakes on my latest build. They're identical to high-end Cane Creek ones. I tossed the pads that came with it and put on Kool Stops. They work identical in stopping power to my Shimano brakes with the same shoes.
    So the brakes with the shoes = suck, the brakes with good shoes = great value.
    I have a single track mind
    Resident Curmudgeon
    Nov 2005
    I put some on my commuter. As everyone else has said, the pads have to go. I put Kool Stop Salmons on & the brakes were quite good. I don't think they were as good as my Ultegras or Dura Ace, but they were fine.
    Reputation: Kuma601's Avatar
    I've seen sets being sold at ~$40 or so. I'd buy some for a beater bike and swap the pads. Knowing me, I prefer matched bits so whatever the gruppo is, I'd get the same brakes.
    Sep 2004
    You might think that Tektro, after reading hundreds of bike board threads saying their brakes would be OK if they are fitted would better pads, would make some changes?
    Adventure Seeker
    Jun 2008
    Quote Originally Posted by jmoryl View Post
    If the read them, there would be a small chance. But I'd bet that most people who use them never try different shoes. Tektro would be catering to 1% of its customers by swapping them out. Then, that would hurt the other brands and many local shops.
    Jun 2007
    I'll bet Tektro's marketing strategy is that when people are pricing lower priced bikes and / or calipers, they are price shopping pure and simple and (a) most likely won't even notice whether the brakes are as good as they can possibly be or (b) if they do decide to buy new pads, they don't even think back to what their cost would have been if they'd bought a better calipers/pads. They don't think of $realcost = $loworiginalprice +$ newpads. They only remember $loworiginalprice
    Aug 2009
    My other bikes have old el-cheapo single-pivot calipers or disc brakes, so I can't compare directly, but I would echo that the stock Tektro pads seem to be poor. They especially eat up the aluminum brake track on my rims pretty badly.
    Apr 2010
    the low end ones do. The came on my entry level cannondale. Pads helped, but when I moved to Force brakes I was amazed. Oh course, they don't compare to disks, but that's another battle for me to fight
    It's a fire road.............
    I'm on a road bike..........
    They have enough in common to blast down it.
    Aug 2011
    The stock Tektro pads are downright dangerous, especially if you are (like me) new to road bikes and coming from hydraulic discs on a mtb - I nearly sailed through a busy intersection more than once before I discovered kool stops, now no issues with them.
    Sep 2011
    Quote Originally Posted by tasdevl View Post
    I was shocked also. I just took my new (to me) road bike out for the first real time and what a difference. I was really let down by the brakes (dura ace 7800) compared to my elixer 5 and XT hydro setups... the pads are a little old though.
    Should I swap pads out if they have been sitting for 3 years or so?
    LC
    LC is offline
    Yes, swap the pads. Kool stops or Swiss stops should be installed on any bike that needs to actually stop. If your cheap then at least change out the front set.
    Apr 2010
    Quote Originally Posted by vierzwanzig View Post
    IMHO, yes. The older 7800 dura ace compound left a lot to be desired.
    You can try the koolstop dual compound, or salmon if its wet a lot.
    SRAM/Swissstop GHP2 (dark green) pads are great. I use them.
    The 7900 dura ace pads are way better than the 7800. You could try those too.
    Jun 2007
    Quote Originally Posted by ziscwg View Post
    +1 that the 7900 pads are excellent. I don't have a lot of comparison, but they're as good as any I've used, and often more available locally than other brands.
    I'd be interested in hearing from anyone who has compared the current 7900 pads to the current lower level Shimano pads which are a little cheaper.
    Reputation: wheelsgman's Avatar
    Dec 2005
    I have Tektro R530 dual pivot and changing to kool stop pads made a world of difference. but the Tektro caliper return spring does feel alittle weaker than Shimano.
    Sep 2011
    Quote Originally Posted by Camilo View Post
    Thanks a lot for the responses guys. I will try to swap out the pads and get a good feel before I report back.
    Thanks again
    Reputation: new2rd's Avatar
    Aug 2010
    I have some kind of Tektro brakes on my 2011 Specialized Roubaix Apex... what model of kool stops or swiss stops do you recommend? I went to the kool stop webpage and there were many choices.
    Sep 2005
    Quote Originally Posted by new2rd View Post
    It's worth the couple bucks extra to get one of the models with the spherical washers that allow easy and precise angle adjustment. So it's the Supra 2 if you want to go with the inexpensive one-piece pad, or the Dura type holders if you want fancier-looking metal hardware with replaceable pads. I'd go with the Supra 2. And I like the plain salmon compound personally.
    Kool Stop Salmon Brake Pads for Bicycles from Harris Cyclery
    Apr 2010
    Quote Originally Posted by JCavilia View Post
    I agree, get the DuraType holders and pads. I got mine at Amazon. They line up real easy
  1. new tektro cx brakes
    By CDB in forum Cyclocross
    Last Post: 08-26-2009, 05:02 AM
  2. Tektro(?) Brakes
    By meeshu in forum Components, Wrenching
    Last Post: 03-23-2008, 09:59 PM
  3. TEKTRO R-750 Brakes
    By gianniboy007 in forum Components, Wrenching
    Last Post: 02-12-2007, 05:09 PM
  4. What should you do with Tektro brakes?
    By JAragon in forum Components, Wrenching
    Last Post: 04-26-2006, 02:54 PM
  5. Tektro ROAD brakes
    By nick53nick in forum Components, Wrenching
    Last Post: 06-08-2005, 02:04 PM
