Don't like full Syncro Di2
Results 1 to 4 of 4
    Reputation: Srode's Avatar
    Aug 2012
    I tried full Syncro Di2 today, really don't like how long it takes for the rear to shift after the front drops to the small ring, if that happened in a pace line someone would be in my rear wheel. Does this get better if I set it to faster shifting?
    Glad you can change shift modes while riding from a Garmin, would have been a pain to have to stop and whip out my mobile phone to switch it back to manual._
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    In e-tube, change the shifting speed of the RD.
    You don't need a bike computer to change shifting modes on Di2, double tap the button on your Junction A.
    Oct 2017
    I tried full synchro for one ride. In my opinion, it really doesn't give any benefit to normal road riding. The only real application I could see would be time trial/triathlon.
    Semi synchro (I call this compensation mode) works ok, and it does provide more benefit that full synchro fir rode riding. I rode in this mode for the better part of a season. What I found was, the more I used it, the less I liked it. There are many cases where a compensation shift is not needed or wanted. I just finally went back to standard shifting mode and have left it there. I might give semi-synchro another shot, but using only one compensating shift per FD shift and see if that works better for me.
    Aug 2012
    I changed the shifting speed to the quickest setting and I still think it drops to much to fast before it shifts up. I also played with the shift points. The reason I want to use this is to make sure I can use a 11/36 cassette with a 6870 GS RDR and not have slack in the chain when I'm in 34/11. Wish there was a way to block combinations of gears, so the extremes were only accessible by shifting to a different ring. That's essentially what full Syncro does, just not as fast as I would like it. For me, I would start the rear before the front to prevent the delay. I'll try playing with the speed for syncroshift which is a different setting, maybe that would help. It's on normal now but slower settings are accessible.
    Gravel Rocks
    Trek Domane
    Trek Crockett
  1. Di2 Syncro Shift Problem
    By ultimobici in forum Components, Wrenching
    Last Post: 01-05-2019, 03:55 PM
  2. Campagnolo Syncro pulley Question
    By onespeedbiker in forum Retro-Classic
    Last Post: 09-06-2010, 04:43 PM
  3. Campy Campa Campagnolo Syncro DT shifters
    By paredown in forum Retro-Classic
    Last Post: 09-03-2010, 05:05 PM
  4. Replies: 12
    Last Post: 10-17-2008, 05:48 PM
  5. Campy Syncro question.
    By robert_shawn in forum Components, Wrenching
    Last Post: 10-06-2005, 04:06 PM
