Downtube Shifters on Modern Derailleurs?
Results 1 to 13 of 13
    Jul 2012
    In theory, could you mount and use downtube shifters in friction mode on modern (road) derailleurs only limited by the shifter total cable pull?
    Specifically:
    Dura Ace DT shifters (I believe 7700 - rated 9 speed?)
    SRAM Force 22 WiFli
    Shimano 11-32 Cassette
    Iíve read itís ďpossibleĒ with limits and in this case, probably swapping to a 9 speed cassette.
    Anyone try this and successful? Or not possible and Iíd need a different/older rear derailleur?
    Apr 2014
    Any non-indexed down tube shifter will work with any range of cassette if that's the way you want to go. The Dura Ace 7700 dt shifters are a good choice. Another good choice is the Suntour Superbe Pro which has a ratcheting power shift in friction mode, just like the Simplex levers.
    Shifting however will take practice to get the shifts accurate & smooth because with 11 gears, its very easy to over shift & miss the gear that you actually wanted. Its just like driving a stick shift for the first time but with practice you will get more used to doing it.
    Feb 2002
    Quote Originally Posted by stan01 View Post
    I would be interested in hearing from someone who did this. Back in the day with 7s friction shifting, many were challenged by the need to slightly over-shift and then center the derailleur with a smooth motion. This technique would be additionally challenged with 11s spacing, though the addition of shifting ramps, improved chains, floating top pulleys, etc. may address some of this.
    jkc
    jkc is online now
    Jun 2014
    I was using my 7 speed Ultegra drivetrain on my trainer with 11 speed cassette (12-25) for awhile. The front was a pain but the rear was fine.
    Sep 2011
    Bar-end shifters are downtube shifters mounted to handlebar plugs. If you want to run 9, 10 or 11 speed cassette and derailleur, just get a set of 9, 10 or 11 speed shifters. No need to run in friction mode unless you just really want to do that. Microshift makes good shifters at a reasonable price for this.
    Jul 2012
    Thanks for everyoneís feedback! Took it to the shop today and the mechanic will see what they can do!
    Iíll post my results.
    Shimano Dura Ace 7700 Downtube shifters
    SRAM Force 22 WiFli
    SRAM 8 speed chain
    SRAM 11-32 8 speed cassette
    'brifter' is a lame word.
    It's going to be friction so it'll work fine, just don't try to use the indexing on the shifter.
    I work for some bike racers
    and a bunch of skateboards
    Jul 2012
    Yeah, Iím actually assuming itíll work especially in friction mode and only using 8 speeds which I believe is lower than the 9 the Dura Aceís are rated for.
    Quote Originally Posted by instantturtle View Post
    Well you've also got a SRAM derailleur and Shimano shifters...no way that would work together, other than in friction mode.
    Reputation: PBL450's Avatar
    Apr 2014
    Im sure Iím missing something here, but why?
    To date, philosophers have merely interpreted the world in various ways. The point however is to change it.
    Really? Because SRAM and Shimano have different cable pull : derailleur movement ratios. They always have. That and the fact there here has never been an 8 or 9 speed SRAM road derailleur so even if the ratio was compatible you'd have a 10 speed shifter and an 8 or 9 speed cassette. Friction is the only way to make this work.
    Apr 2014
    Thats a great explanation! It nails why it works and how!! My question was more geared toward why would you run friction if you have the option of indexed short of a nice vintage ride?
    Reputation: velodog's Avatar
    Sep 2007
    If you're going to run friction, and Simplex Retrofriction levers pull enough cable to work with your derailleur of choice, I would recommend them. They are, IMO, the finest friction shifters on the planet. They haven't been made in years, and can get pricey for NOS, but some nice used ones can be found at fair prices, if you shop around a bit.
    https://bikeretrogrouch.blogspot.com...-part-one.html
    https://sportifbicycle.blogspot.com/...rs-part-1.html
    https://sportifbicycle.blogspot.com/...rs-part-2.html
    https://www.ebay.com/itm/Vintage-Sim...YAAOSw0gVeCJsa
    I have a set mounted on an old Campagnolo equipped bike; and another set in the cabinet, just so I know I have them.
    Too old to ride plastic
  1. Eroica bike - downtube shifters with modern 10 speed?
    By artiemeister in forum Retro-Classic
    Last Post: 02-12-2019, 07:35 AM
  2. Replies: 4
    Last Post: 05-21-2013, 12:24 PM
  3. retro-modern downtube shifters steel frame old school 8 speed FUJI!
    By Creakyknees in forum Bikes, Frames and Forks
    Last Post: 05-17-2013, 04:17 PM
  4. Replies: 0
    Last Post: 05-13-2013, 01:52 PM
  5. Using modern Derailleurs w/friction shifters?
    By phototone in forum Components, Wrenching
    Last Post: 10-27-2004, 12:57 PM
