Drivetrain Compatibility.................
Results 1 to 6 of 6
    Reputation: Lombard's Avatar
    May 2014
    A very good article by Art's Cyclery. Yes, I know it's 4 years old, but still lots of good info:
    Art's Cyclery Blog » Science Behind the Magic | Drivetrain Compatibility
    Statistics are like bikinis. What they reveal is suggestive, but what they conceal is vital. -- Aaron Levenstein
    Curmudgeon
    Reputation: SHIF's Avatar
    Jul 2009
    Indeed this is some good reading, thanks for posting the link.
    Out riding.
    Reputation: 1500SLR's Avatar
    Sep 2018
    It doesn't matter that its old. It covers everything except 1x12.
    Reputation: smokva's Avatar
    Jul 2004
    Quote Originally Posted by 1500SLR View Post
    Also, It doesnt cover Campagnolo 2nd gen 11 speed and Campagnolo 12 speed.
    Sent from my SM-G925F using Tapatalk
    Ante Smokrovic
    2009 De Rosa Neo Pro - Fedaia, Giau, Pordoi, Sella, Gardena, Campalongo, Falzarego, Valparola, San Pellegrino, Valles, Staulanza, Vrič, Mangart, Furcia...
    2003 De Rosa Team - Stelvio, Gavia, Mortirolo, Bonette, Agnel, Izoard, Fedaia, Giau, Pordoi, San Pellegrino, Staulanza, Manghen, Vrič, Učka, Mangart, Biokovo, Eisentalhhe, Schonfeld, Schiestelscharte, Flattnitz...
    Out riding.
    Sep 2018
    Yes, I wasn't paying enough attention.
    I measured the cable pulls on the 2015+ ultrashift levers recently and fould that the total cable pull is significantly longer - 31mm compared to only 28.5mm for the older 11 speed shifters. This time I measure the cable pulls by a different method, so the small cog limit screw was not affecting the readings. That method showed both the old and new versions pulled 4mm the first time. The remaining shifts on the old model were the same as I measured 9 years ago. The new shifters have a lot of 3mm shifts, where the old ones had 2.5mm.
    What this means is that the new shifters pull too much cable for an older RD. If you put a new RD on a bike with the old shifters, they won't pull enough cable. I have the older shifters on a bike where I need a 12-32 cassette, so I bought a new Potenza RD and used the same mod that I did long ago to make a 10 speed shifter work with 11 speed. I ground the cable clamp screw down to the root of the threads, where the cable contacts the bolt, and filed off some material on the clamping plate, to allow the cable to move over against the bolt. Someone else tried a slightly different approach and slotted the bolt hole, so the plate would move close to the bolt. There is a groove in this plate, wher the cable is supposed to rest. However you do it, this mod shortens the lever arm and increases the travel enough to shift well.
  1. Sram S900 crank with Dura Ace 7800 drivetrain? Compatibility?
    By tyro in forum Components, Wrenching
    Last Post: 01-22-2009, 10:07 PM
  2. Drivetrain compatibility between Campag, Shimano and SRAM
    By Lab Worker in forum Components, Wrenching
    Last Post: 01-04-2009, 08:09 PM
  3. SRAM 10-speed cassette, XT-hub and Shimano drivetrain compatibility ?
    By Imashaghen in forum Components, Wrenching
    Last Post: 04-05-2008, 07:10 AM
  4. Compatibility -- Campy drivetrain and ultegra chain
    By nbrennan in forum Components, Wrenching
    Last Post: 03-16-2007, 05:56 AM
  5. Shimano hub / Campy drivetrain Compatibility Question:
    By Pablo in forum Components, Wrenching
    Last Post: 11-28-2005, 06:00 PM
