Results 1 to 5 of 5
    Apr 2016
    Dumb disc brake question
    I just picked up a bike with disc brakes. I want to get another set of wheels. The current wheels use 6 bolt discs. The set I'm looking at uses centerlock. Aside from how the discs mount to the wheel, is there any difference? I'll get a set of centerlock discs (same diameter as what I have) for the new wheels, so I can just switch them out quickly. I assume this won't be an issue, but I wanted to ask just to make sure before I put down the money for these wheels.
    JSR
    JSR is offline
    Feb 2006
    I had a similar question not long ago. This may help. http://forums.roadbikereview.com/whe...ty-362443.html
    Apr 2016
    Ahh. Thanks. I'll take a look through that thread.
    'brifter' is a lame word.
    Simple answer is they're supposed to be the same. The slightly more detailed answer is you'll almost always have to adjust the caliper in relation to the rotor whenever you swap from one wheel to another unless it's the exact same hub/rotor combination.
    I work for some bike racers
    and a bunch of skateboards
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    OR...shim the rotors to match.
  1. Dumb ass, dumb bell
    By Fredke in forum Politics Only
    Last Post: 12-01-2010, 03:18 PM
  2. Dumb brake question....
    By Donzo98 in forum Components, Wrenching
    Last Post: 12-21-2008, 05:59 AM
  3. Dumb brake question
    By canthidefromme in forum Hot Deals
    Last Post: 01-04-2007, 04:14 PM
  4. SS with vertical dropouts... Dumb luck or just dumb?
    By Frith in forum Fixed/Single Speed
    Last Post: 08-05-2005, 08:02 AM
  5. dumb question about cantilever brake and road forks
    By sinican in forum Components, Wrenching
    Last Post: 03-19-2004, 08:33 PM
