Are Dura-Ace 7900 Brifters compatible with Ultegra 6700 Derailleurs?
Results 1 to 16 of 16
    Sep 2010
    Sorry I know Ive seen the answer on here somewhere but can't seem to find it through search.
    Thanks
    Reputation: Ventruck's Avatar
    Mar 2009
    Yep
    Said in another thread that 5700/6700/7900 are cross compatible to a far extent.
    Los Barriles, BCS, Mexico
    Reputation: DaveT's Avatar
    You can use a 6700 rear derailleur with the 7900 shifters but not the 6700 front der. A 7900 front derailleur has to be used with those shifters.
    Trying to cram the rest of my life into the rest of my life!
    Nov 2011
    Quote Originally Posted by DaveT View Post
    That's the way I understood it too. But last week I installed a pair on a Cervelo, and they seem to work fine so far. Do you know exactly why they aren't supposed to work?
    I also thought that the brakes won't work as well, possibly due to a change in the lever's pivot point which changes the leverage. Again, seem to work fine.
    The Pb Torpedo
    Jun 2011
    [disclaimer: I am not a wrench. (Only an atomic physicist, in a past life.) But that won't stop me from adding to my post count while we wait for someone who knows for sure to chime in.]
    I believe that 7900 uses a different cable pull ratio for the front derailleur, so performance might be sub-optimal with a 6700 derailleur. But if it works for you... Also, I believe you lose the ability to trim the front derailleur with the 7900 brifters, which the DA derailleur is designed not to need (via the shape of the cage), but 6700 will generally need as you move toward being cross-chained.
    As for brakes, DA 7900, U 6700 and 105 5700 all use compatible lever-caliper cable pulls, which are different than prior generations. (I think more cable movement for a given amount of pad movement?) Levers and calipers can be mixed with other generations, but performance will not be as designed. That said, last summer I rode extensively on a bike with 5700 levers and below-105-level Shimano calipers, and braking performance was fine.
    Sep 2010
    Not worried about caliper compatibility as its for a cross bike, but I do need to verify the derailleurs. Sounds like the front may be a no go.
    Anybody know for sure? Can't find any answers on the Shimano site.
    Mar 2009
    Quote Originally Posted by sqwk77 View Post
    Shimano's chart says ST-7900 shifters are compatible with only the FD-7900:
    http://www.shimano.com/publish/conte...ty%20Chart.pdf
    I wasn't convinced to assume incompatibility previously because front derailleurs aren't at all that fancy (at least the non-electric ones), especially when I've read accounts about the cross compatibility between brands in such regards (I myself got Campy Centaur shifters controlling an FD-6600, but let's not stray off-topic).
    Best interest to try to just get things matching.
    I have personal experience using 7900 shifters with 6700 and 7800 rear derailleurs and 6700/7800/6600 brake calipers. All worked better than well in those combos. I have no experience using anything other than 7900 front derailleur with the 7900 shifters, but everything that I've read says that a 7900 front der is to be used with those shifters. Anything else won't work properly.
    Reputation: nightfend's Avatar
    Mar 2009
    Don't believe Shimano. You can use 7900 shifters with older front and rear derailleurs and it works fine. See plenty of real world examples of this recently.
    Mar 2009
    Yes, I know for sure. I've seen these bikes ridden in person, and they work fine. My example used 7900 shifters with 7800 rear and front derailleurs.
    Mar 2018
    The ST-7900 / FD-7900 combo does not have a trim adjustment as does the ST-6700 / FD-6700.
    'brifter' is a lame word.
    Quote Originally Posted by amoz04t View Post
    Not only are you almost 7 years late...you're wrong. There is a trim on the 7900 shifter for the small ring.
    http://si.shimano.com/pdfs/si/SI-6RT0A-004-ENG.PDF
    I work for some bike racers
    and a bunch of skateboards
    Mar 2018
    I'm sorry, sir - I didn't pay attention to the date stamp of the original question. I hope the person that posted the question received a more timely answer. Haha. And I hope you feel better soon.
    I believe my response is correct. I don't see any discussion about the trim function on the SIs for ST-7900 or FD-7900 as I do for ST-6700 and FD-6700. Also, i thought I saw another post that stated that the 7900 Dura-Ace series was the first to eliminate the noise trim function.
    Click on the link I provided, it describes the small ring trim. Trust me.
    Mar 2018
    Oh I see that you are referring to the operation of lever "a" to move the FD outward and avoid chain touching the inside surface of the outer plate. This is different that the noise trim function on the ST-6700; that trim uses lever "b" to eliminate noise from chain rub against inner surface of inner plate.
    So back to the original question - no a FD-6700 is not compatible with ST-7900.
    I don't understand your first paragraph but what it boils down to is that 7900 levers have trim for the small ring but not the large ring.
    I've tried 7900 levers with a 6700 front der. and in that case you are correct. I could not adjust to eliminate rub from the big ring without that trim. But it was real close and that bike had really short chainstays. I may have been able to adjust so trim on the large wasn't needed in the big ring on a bike with much longer chainstays so the angle was less sharp.
    Either way, I doubt anyone cares in 2018.
  1. Replies: 5
    Last Post: 07-10-2010, 12:17 PM
  2. Replies: 11
    Last Post: 12-28-2009, 10:27 AM
  3. Ultegra 6700 or Dura-Ace 7900
    By petehm in forum Components, Wrenching
    Last Post: 12-22-2009, 08:11 PM
  4. Ultegra 6700 Dura ace 7900 chains
    By gcedillo in forum Components, Wrenching
    Last Post: 11-25-2009, 11:56 PM
  5. Dura-Ace 9spd shifters compatible with Ultegra derailleurs?
    By myusernamewastaken in forum Components, Wrenching
    Last Post: 09-23-2005, 12:43 PM
