Dura Ace 9100 shifters chewing up cables same as 9000 - Gutted after $$ upgrade
Results 1 to 25 of 34
    private
    Sep 2013
    I am completely gutted . My 7 month use 9100 just chewed up a derailleur cable Same fault as 9000 , also know as "that cable-breaking-in-the-shifter thing" , and Shimano also started waranteing shifters , replacing with 9001.
    I purchased a complete 9100 brake, shifter and derailleur mini group kits. After 7 months use ONLY the rear bird nested in side the rear (right side shifter) . Bike shop mechanic manged to get it out BUT the changer is now intermittently miss firing , wont drop down when when flicking the inner leaver , nothing happens , need several attempts . I suspect its damaged
    Also , the dura ace cable polymer coating started to fall off after 5 months , now clogging up outer housing , its like a snake has shed its skin , the skin wont fall off , all bunched up in knots, more prevalent on brake inner cables
    Super frustrated as I spent big $$$ to fix the 9000 faulting, now this S*** / cost to endure . I won't go into the rear derailleur known problem with noise in big chain ring that drives a cyclist crazy nuts . We cycle to be at one with nature.. not have to listen to a rattly fan in the back
    What do you do >?
    please SHIMANO can you make a groups set that works better than 7800? and without faults and costly cable replacements every 6-7 months. AKA substandard ****?
    'brifter' is a lame word.
    Get over it...they've been breaking cables forever and Shimano probably won't fix it anytime soon. It's crazy easy to get the broken end of the cable out of the newer shifters, your mechanic should have been able to get any remaining pieces out. Of course it happens on the rear more often...you shift much more often in the rear, probably 30-50:1. Don't have the cable replaced w/ polymer or any other coated cable, used regular stainless. Now you know how often you'll have to replace them before they fray & break. D/A and Ultegra are race level parts, they will require maintenance to keep them working properly.
    I work for some bike racers
    and a bunch of skateboards
    Reputation: Srode's Avatar
    Aug 2012
    I average around 5 front to 330 rear on a 1.5 hour loop I take fairly often with about 1200 feet of ascent. Of course the terrain and gearing will move the results one way or another.
    If you can't stand the frequency of cables braking, Di2 would have been the better option for you. Or learn to change them yourself - it's really not that hard if you are mechanically inclined. and take your time.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    BH G7 Disc
    Trek Crockett
    Banned forever.....or not
    Aug 2002
    How many miles???? Not sure why they would break if you changed them every 5000 miles.
    Dogbert.
    I>U
    Quote Originally Posted by MR_GRUMPY View Post
    People regularly have problems between 1500-2500miles.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Yup. I change my rear cable every 2000 miles whether it needs it or not. Much easier than fishing out broken pieces of wire inside the shifter.
    This problem started happening with Shimano shifters since the generation where the shifter cable was routed under the bar tape.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Had a guy on a gravel grinder in May with a barely 2 month old Salsa. He had to take a 22-speed Ultegra bike and make it a 2-speed in the field less than half-way through the ride. It was ludicrous.
    Aug 2002
    Wow....I'm still using 7800. I guess the "new and improved" under that bar tape cables and housing has it's drawbacks. I guess that all those bends equal more friction. I've often wondered why the housing for the new shifters costs so much more than the old SP40...(ouch, changing your cables four times a year would really suck)
    Dogbert.
    I>U
    Banned Sock Puppet
    May 2014
    To say the least! That happens when you trade functionality for aesthetics.
    Jan 2005
    It is all about implementation.
    Do you hear legions of SRAM and Campagnolo complaining about cable-snapped-in-the-shifter syndrome?
    Banned Sock Puppet
    May 2014
    Point taken. One has to wonder why Shimano is on their third generation on under the handlebar cabling shifters and haven't taken care of this problem yet. I guess it hasn't hit them in the $$$ yet.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by 1synergy View Post
    Time is irrelevant. How many miles?
    There is an aerodynamic benefit of removing the exposed cables so it's not just aesthetics. And of course.... SRAM does it without issues.
    Banned Sock Puppet
    May 2014
    Hahaha! Really? How much do two cable housings contribute to wind resistance?
    Apr 2013
    What do you do >?
    i change my cables ever 2-2.5k. Problem solved
    I imagine that contributes. But I'm guessing in a lot of cases people getting less miles out of newer groups are also using not so great internally routed frames and were not back when they had 7800 or prior.
    No good reason for it happening much quicker than campy or sram (from what I've heard).
    But it's really no big deal to just treat cables as a swear item and replace them when needed. I do it when I replace my chain. I definitely don't need to do it that soon but I don't use a bike computer so that's what I use to measure how long it's been.
    I don't think the routing has anything to do with it. If there were a bunch of really tight curves and they caused enough drag to be a problem then the shifting would absolutely suck on those bikes. The fraying takes place inside the shifter where the cable is wound/unwound around a small round shift drum/gear...apparently just enough smaller than SRAM and Campy that it destroys cables. I see virtually no cables fray anywhere else except for where they take the sharp bend at the rear derailleur after coming out of the housing.
    I definitely agree w/ just treating them as wear items and replacing them before they reach the point of fraying.
    tlg
    tlg is offline
    May 2011
    ^^^ This.
    I've seen dozens of cables fray inside the shifter. I've never seen a cable fray inside a frame or elsewhere.
    Aug 2012
    ^^^ This.
    I've never had a frayed Di2 cable........
    Gravel Rocks
    Trek Domane
    BH G7 Disc
    Trek Crockett
    tlg
    tlg is offline
    May 2011
    Me either
    (haven't ever needed to replace cables or adjust a derailleur either)
    And it does suck (from what I've been told by a few people who could never get good shifting on certain internal frames not my own experience)
    I know they only fray inside the shifter. But my 'guess' is that needing to pull harder to over come more friction elsewhere would have an impact on that area too because that's where the pulling is happening.
    Reputation: faulker479's Avatar
    Jan 2015
    So who told the OP that this issue was resolved with 9100 over the 9000?
    The pull ratio is still the same and I don't believe too much was changed as far as cable routing and size of the shifter.
    I would be equally mad at the person who told the OP that 9100 would fix this widely known issue. Well, widely known to everyone except Shimano.
    Feb 2013
    I didn't tell the OP, but did think that the 9100 series shifters were meant to fix this issue?
    I've only had this issue twice, once on my Ultegra 6700 shifters on a morning ride, and again later that SAME day on my DA 9000 shifters on a different bike, what are the odds!
    edit: now that I think about it, didn't Shimano come out with R9001 shifters to "fix" the cable problem?
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by faulker479 View Post
    This problem has absolutely NOTHING to do with cable routing, shift ratios or anything else EXCEPT the internal design of the shifter. Please read what CXWrench said in Post #16:
    I don't think the routing has anything to do with it. If there were a bunch of really tight curves and they caused enough drag to be a problem then the shifting would absolutely suck on those bikes. The fraying takes place inside the shifter where the cable is wound/unwound around a small round shift drum/gear...apparently just enough smaller than SRAM and Campy that it destroys cables..
    I think you are guessing. As am I by thinking bad internal cable routing that requires more force to pull could play a role.
    If I remember correctly you have a frame with internal routing and have mentioned chewing up cables in less miles than I've ever heard of it happening to anyone else. Certainly thousands less than myself with external routing and with my shifting habits I doubt you shifting more is a factor. Anecdote.......but........
    Aug 2012
    Counter point, when I had cable shifting and internal routing I was getting about 7000 miles out of a rear cable on Ultegra 6800 and the thing i did for good life was lube the cable and track at the 90 degree turn entering the shifter. Inside the frame there are no more contact points for the cable than an external design, and if anything there should be less friction because less of the cable is exposed to the elements to drag stuff into the housing and create friction.
    Gravel Rocks
    Trek Domane
    BH G7 Disc
    Trek Crockett
  1. Replies: 2
    Last Post: 07-07-2017, 08:34 AM
  2. Jagwire Road Pro vs. Dura-ace 9000 shift cables
    By sasquatch16 in forum Components, Wrenching
    Last Post: 08-09-2016, 07:31 AM
  3. Dura-ace 9000 mechanical cables - Where?
    By StillKeen in forum Components, Wrenching
    Last Post: 03-20-2014, 04:03 AM
  4. Dura Ace WH-9000-C24-TU vs WH-9000-C24-TL
    By Philhumphrey in forum Wheels and Tires
    Last Post: 02-22-2014, 12:50 PM
  5. Just gutted...
    By bikeboy389 in forum The Lounge
    Last Post: 12-13-2006, 02:16 PM
