Is Dura-Ace crank compatible with Ultegra bottom bracket?
Results 1 to 3 of 3
    Oct 2005
    A buddy is swapping his 10speed Dura Ace crankset for somthing else and has offered it to me cheap. I currently have a 10 speed Ultegra crankset. Will the DA crank bolt right on? Does the bottom bracket need to be swapped as well. Also, how is a crank arm measured? I'm assuming it is from center of the crank axel to center point of the threaded hole where the pedals are mounted. Thanks in advance.
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    Yes for 9 -Speed
    I don't have experience with Shimano 10 speed, but I use Ultegra BB on my 9 speed Dura Ace Cranks. I'd be surprised if this wasn't true for the 10 speed.
    n00bsauce
    Reputation: Mel Erickson's Avatar
    Yes, they are compatible. No, you shouldn't have to change the BB assuming the current one is the proper length for your setup.
    "Those who can make you believe absurdities can make you commit atrocities." Voltaire
    There are your fog people & your sun people, he said. I said I wasn't sure which kind I was. He nodded. Fog'll do that to you, he said.
    "We are all ignorant about most things."
    Mel Erickson
