FD-6800 setup
Results 1 to 7 of 7
Thread: FD-6800 setup
    Feb 2013
    FD-6800 setup
    Shimano tech docs go into a lot of detail about where the derailleur should be and which way the cable should be attached. One thing they do not mention unless I missed it is what position the barrel adjuster should be when setting up. All the loose, tight or in the middle.
    Thanks
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Barrel adjuster should be threaded all the way in. Pull cable tight and secure. Use barrel adjuster to add tension. Medium may work, but I've not had any luck in the past pulling the cable tight enough by hand where I didn't have to use at least half of the barrel adjuster.
    Sent from my SM-G977U using Tapatalk
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    'brifter' is a lame word.
    Not sure how that would be different from any other derailleur...start all the way or nearly all the way in. Cables never get tighter. Did you use the tool to determine whether the converter should be on or off?
    I work for some bike racers
    and a bunch of skateboards
    Feb 2013
    I have the tool and plan on setting converter as explained. Thanks for info.
    Russian Troll Farmer
    Sep 2016
    I'm of the though that about 3/4 of the way in, just in case you need to adjust a bit inward due to less-than-ideal derailleur adjustment.
    "L'enfer, c'est les autres"
    Feb 2013
    Installed derailleur this weekend and it works fine but for the life of me I could not see any difference with that converter piece. Even with a magnifying glass it looked perfectly centered. No offset at all.
    On some frames the cable will be lined up dead center w/ the line on the converter tool...exactly 50/50. In those cases there will be no difference.
  1. Replies: 8
    Last Post: 05-30-2016, 06:04 PM
  2. Problem installing 6800 Front Derailleur FD-6800
    By TiCoyote in forum Components, Wrenching
    Last Post: 02-14-2015, 10:44 AM
  3. Chain wrap capacity with 6800 and use of Force 22 crank with 6800
    By nkranhold in forum Components, Wrenching
    Last Post: 02-11-2014, 08:41 AM
  4. recommended ultegra 6800 setup
    By kingArthur in forum Components, Wrenching
    Last Post: 02-08-2014, 07:51 PM
  5. Ultegra 6800 FD with 105 Components
    By BroomVikin in forum Components, Wrenching
    Last Post: 11-16-2013, 05:58 AM
