Finding rear axle for old Mavic wheel
Results 1 to 16 of 16
    soliton
    Jul 2012
    I was helping a buddy rebuild his old rear wheel Mavic Aksium vintage around 2008. Everything went fine cleaned out freehub and replaced all the bearings. Well... almost everything. We found that on the drive side the axle had snapped about 10-15 mm from the end. It was a pretty clean break so I guess the skewer kept it wedged tightly against the remainder so that there was not a obvious problem riding. At any rate we have had no luck trying to locate a replacement part. We did find the Mavic part number # 323 482 01 but no vendors as of yet. Does anyone have any suggestions on locating. We are trying to go via email with Mavic now but they want the wheel serial number which is rubbed illegible. Thanks for any ideas on obtaining the part or a suitable substitute.
    gazing from the shadows
    Jan 2003
    Have you tried www.mavicparts.com ?
    I found it by a search, never used the site. I don't endorse it, I don't NOT endorse it. Seems an options though.
    a real member's member
    Jul 2016
    is it a cartridge bearing hub? or will a regular axle from Wheels Mfg work? have you tried to find a replacement hub or axle on ebay? can you post a photo of the axle?
    Jan 2003
    Quote Originally Posted by blackfrancois View Post
    Let's go even more basic.
    Have you gone into a local bike shop and asked if they have one of "these"? (hold up broken axle).
    'brifter' is a lame word.
    It's definitely a cartridge bearing hub. The axle is definitely proprietary. No other axle will work.
    Quote Originally Posted by QuiQuaeQuod View Post
    Slim chance of that happening but definitely worth a try.
    I work for some bike racers
    and a bunch of skateboards
    Jan 2003
    As a last resort, would going the weld and machine smooth route be an option?
    As a last resort I'd buy another wheel. Finding someone that would be able to weld a broken axle together and have it end up straight would be harder than either finding a replacement and/or a new wheel.
    Feb 2002
    Highly unlikely to be successful unless the price paid for the welding was exhorbitant. IOW, buy a new wheel if axle cannot be found. Ah, the joy of MAVIC and their proprietary parts. And for the OP, there is actually a Wheels and Tires forum here.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Have your local Mavic dealer call Mavic. Give them the serial number for the wheel - opposite the valve stem. You'd be surprise what Mavic has in stock for parts. IIRC, the Aksium was pretty much unchanged for quite a few years.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    soliton
    Jul 2012
    Quote Originally Posted by frdfandc View Post
    Yep tried Mavic. They said wheel too old for them to have the part. Don't know if true or don't want to be bothered. I even have the Mavic part number 323 482 01.
    soliton
    Jul 2012
    Well... I have tried at a couple of the LBS's with no results. That is not to say that there is not one that will respond differently.
    soliton
    Jul 2012
    There was/is another 12mm of threaded axle at the top. That's the part that sheared off.
    Attached Thumbnails Attached Thumbnails Finding rear axle for old Mavic wheel-img_0048.jpg
    Quote Originally Posted by soliton View Post
    Sure, try every shop in the country and you might eventually fine one w/ the part.
    It's not even that great of a wheel...you could probably buy another for not very much. Or some better...now there's an idea.
    Oct 2002
    https://www.ebay.com/itm/Mavic-Aksiu...6svS:rk:8:pf:0
    get the guy to send you the hub and trash the rest.
    shiit someone bought it already.
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    Kiwisimon's suggestion is a good one. I have a lot of respect for getting long life out of a part and making old stuff new again but .... it's an Aksium wheel and it had a good run. Pick up a good used wheel set off CL.
    Jan 2003
    Sure, that's true. And I certainly would not be trying to save the thing myself.
    But, for a low cost/low chance of success option... take it to a local community college welding class. The instructor might be willing to let the class try to weld cut steel tubes together, then give the "best" student performer a shot at the axle. If it doesn't work out, nothing lost.
    Likely would not work, but having an in with a welding instructor would be worth the hassle for some. Good people to know, ime. And it might work.
    Heck, it might become a standing lesson. A lesson in "why we don't take every job".
  1. broke the rear axle on my old grocery getter
    By blackfrancois in forum Components, Wrenching
    Last Post: 09-22-2018, 06:43 PM
  2. 2009 Mavic Ksyrium Elite rear Axle needed.
    By mikamaral22 in forum Wheels and Tires
    Last Post: 09-24-2015, 04:21 AM
  3. Help finding an affordable Rear Wheel
    By fox_boy in forum Tandems
    Last Post: 11-01-2014, 01:59 PM
  4. setting up rollers -- front roller axle vs front hub axle
    By teleguy57 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-03-2009, 06:39 PM
  5. Mavic Ksyrium SL Rear Axle
    By bwhite_4 in forum Wheels and Tires
    Last Post: 08-24-2008, 05:55 PM
