FreeHub Noise
Results 1 to 8 of 8
Thread: FreeHub Noise
    Oct 2013
    FreeHub Noise
    My new bike has DT Swiss E1800 Spline wheels and the hub ratchet noise when I'm not pedaling is annoying. It is an 11 speed hub.
    I've taken the hub on other wheels apart and had good results with Tri-Flow in that area.
    I now only have T-9 & ProLink lube, & I think they would be too watery. Is there a better lube than tri-flow for this & is there anything I should be aware of.
    BANNED
    Sep 2011
    DT Swiss freehub grease
    Feb 2002
    Any lightweight grease, or grease mixed with oil. 90w gear lube would be quieter too. If the grease is too thick, it could inhibit engagement, particularly in cold weather.
    'brifter' is f'ing stupid
    DT Swiss 'special' grease and nothing else. Not much of it. Apply some to the ramps on one ring, and some to the notches on outside of the rings, that's it. If you overdo it the rings won't engage properly. If you use oil it will leak out. Depending on how much you ride you'll have to do it every 2-8 months.
    You can obviously use different grease if you can't get DT but nothing heavy or really 'webby'.
    #promechaniclife
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    I believe these wheels use those DT370 hubs like in that hub-conversion thread. No star ratchets, just traditional pawls.
    You are correct. DT 'normal' grease for those.
    #promechaniclife
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Grease every 2-8 months just to keep my freehub quiet? I'll stick with my good old reliable quiet Shimano hubs, thanks!
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    Banned Sock Puppet
    May 2014
    i now only have t-9 & prolink lube..........
    Spike......5....4.....3.....2....1........
    "With
    -- DCGriz, RBR.
  1. Swapping RSX 7-speed freehub for 8/9/10 speed freehub, FYI
    By shamethellama in forum Components, Wrenching
    Last Post: 07-11-2015, 04:26 PM
  2. Freehub noise on 2008 Race Lite
    By mtbdcd in forum Wheels and Tires
    Last Post: 06-02-2008, 05:26 AM
  3. Can Fulcrum Racing 1 Shimano freehub be changed to a Campy freehub?
    By slider2453 in forum Components, Wrenching
    Last Post: 04-01-2008, 04:52 AM
  4. Campy Proton Freehub Noise
    By hfc in forum Wheels and Tires
    Last Post: 03-27-2007, 06:47 AM
  5. Freehub or Chain Noise?
    By percy in forum Components, Wrenching
    Last Post: 07-04-2006, 05:08 AM
