Freehub Problem?
Results 1 to 18 of 18
    Apr 2002
    Freehub Problem?
    I went out for a ride this morning. Pedaling backwards would cause the chain to kink up and feel like it would come off. I am now home. I took off the wheel. There is a great deal of resistance turning the cassette counter clockwise.
    Ultegra 9 speed.
    Any insight into this problem will be appreciated.
    Oct 2013
    Take the freehub off and oil the paws.
    Why are you pedaling backwards, that will not make u slowdown!
    BANNED
    Apr 2002
    Just to get pedals into position. I am now in the process of removing the cassette.
    Apr 2002
    Upon removing the cassette I found a long cord in between the freehub and the hub.
    'brifter' is f'ing stupid
    #promechaniclife
    Sep 2011
    That's what I was thinking.
    Oct 2013
    .... wax them? ....no rules!
    ..... WAX , a lot of WAX, that'll fix it.
    BANNED
    Sep 2011
    .... wax them?
    I prefer peanut butter. Chunky is best.
    Apr 2002
    I hate to say this but the problem is not completely solved. When I spin the rear wheel backwards, the pedals turn. What next?
    Sep 2011
    Quote Originally Posted by daniell View Post
    Replace the freehub body, or have a shop replace the freehub body.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by 202cycle View Post
    There could be other issues.
    Check the seals. A bad seal in the freehub can cause this exact problem.
    Feb 2002
    Take it apart and lube the pawls. Feel for bearing friction and binding. If the bearings feel bac you can pry the seals out and lube them, or just buy a new freehub.
    This is completely normal. It's the same as turning the pedals forward. What do you expect to happen?
    #promechaniclife
    Feb 2002
    I think it is more accurate to say that it is common rather than normal. It reflects high friction when coasting. Could be clearances, seals, heavy lube, etc. Decades of Campy freehubs and I have never had one that would have enough friction to move the cranks when the back wheel is spun backward (like you were coasting).
    Spun. Backwards.
    Backwards.
    If you spin the wheel backwards the crank has to turn...the drive is engaged. It has nothing to do w/ seals or anything else. Nothing else can happen. It has nothing to do w/ coasting, the wheel moves forward when coasting.
    #promechaniclife
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Darn you cxwrench with your keen reading eyes and mechanical prowess! Does OP mean forward and the pedals still spin?
    Quote Originally Posted by jetdog9 View Post
    Keen reading eyes? Thanks to the progressive lenses!
    #promechaniclife
    Feb 2002
    Spun. Backwards.
    Backwards.
    Doh! At least I covered my butt a little by saying "like you were coasting."
  1. Swapping RSX 7-speed freehub for 8/9/10 speed freehub, FYI
    By shamethellama in forum Components, Wrenching
    Last Post: 07-11-2015, 04:26 PM
  2. Can Fulcrum Racing 1 Shimano freehub be changed to a Campy freehub?
    By slider2453 in forum Components, Wrenching
    Last Post: 04-01-2008, 04:52 AM
