Front brake adjustment screw loosening: loctite?
Results 1 to 7 of 7
    Sep 2010
    Shimano 105 front brake. The screw that adjusts the brake shoes left/right to center them over the rim keeps loosening itself as I ride, I assume due to vibration since I can't see anything mechanically wrong. Screw is circled in attachment.
    Should I just use some Loctite Blue on this, or is there a better way to solve the issue? (Lock washer? Something else?)
    Sep 2006
    Yes, loctite it.
    Lost in Space...
    Reputation: headloss's Avatar
    Mar 2013
    yup... blue loctite. Start with the most simple solution.
    Idiot at large
    Apr 2010
    Better with Green Loctite, as it is designed to wick into the open gaps of the mating threads.
    2010 Specialized Secteur Elite with the RBR not-approved Mavic Ksyrium Elite wheelset
    2009 Specialized Rockhopper Comp 29er upgraded to SRAM X9 with 1x10 and Stan's Arch EX rims and tubeless.
    2013 Cannondale CAADX-6 Tiagra with 9-speed SLX RD to run 11-32T cassette and Stan's Alpha 400 rims and tubeless
    and
    Some Burton snowboard setups, one with stiff ol' Camber and one with Rocker-Camber-Rocker
    Lost in Space...
    Mar 2013
    Quote Originally Posted by tednugent View Post
    only if the OP doesn't want to pull the screw out first...
    Reputation: JCavilia's Avatar
    Sep 2005
    No no no no no. This is an adjusting screw, which needs to be esily moveable. Read the copy on the green loctite. It's for more permanent installations, and REQUIRES HEATING FOR DISASSEMBLY. It's stickier and harder than the blue when cured.
    Use the blue, back out the screw a bit and drip some on the exposed threads, turn it back in.
    "None of us knows for sure what's out there; that's why we keep looking. Keep your faith; travel hopefully. The universe will surprise you, constantly." The 13th Doctor.
    Sep 2010
    Sounds like blue Loctite is the way to go. Thanks all.
  1. Wonky Front Brake Centering/Adjustment Problems
    By lalahsghost in forum Components, Wrenching
    Last Post: 09-08-2012, 04:42 PM
  2. Sram rival front derailleur adjustment screw bend!
    By Smash in forum Components, Wrenching
    Last Post: 10-21-2011, 11:33 AM
  3. Front end loosening up?
    By DRLski in forum Components, Wrenching
    Last Post: 05-26-2008, 03:06 PM
  4. Front brake screw to short.
    By Plank in forum Components, Wrenching
    Last Post: 10-20-2007, 01:49 PM
  5. removing loctite secured screw
    By dlenmn in forum Components, Wrenching
    Last Post: 03-14-2007, 07:10 PM
