Front deraileur problems
Results 1 to 21 of 21
    Aug 2018
    Started out on a club ride and suddenly the front shifter wouldn't move the chain onto the large front ring. No upper gears. Fiddled with the barrel adjuster to no avail. Left the thing with the bike shop. The groupo is Ultegra, and only about a year old. What causes this?
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    2 things to check. See if you can manually move the FD by pulling on the cable. If you can, then check to make sure that the cable isn't broken inside the shifter.
    It does sound like to me the cable broke inside the shifter.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    How many miles are on the bike? How much resistance do you feel when trying to shift to the larger chainring?
    A broken cable is indeed possible, but it is highly unusual to break a front shifter cable unless you have lots and lots of miles. The rear cable is usually the one that breaks since the rear shifter is used way more than the front shifter.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    I bet $1 that you broke the cable.
    Aug 2018
    How does that happen? Bad roads? A big bump? Rough handling while shifting?
    Aug 2018
    I'd say the bike has, at most, about 600 miles on it. No more. I bought it last year at the end of the season. It's a Trek Emonda 5 on which I swapped the 105 groupo for Ultegra.
    [REDACTED]
    May 2014
    Quote Originally Posted by coondogger View Post
    The cable is most vulnerable inside the shifter where it wraps it tightly in a small circle. When you shift, it wraps and unwraps the cable which eventually leads to fraying. As I said, very unusual for this to happen on a front shifter cable, quite common on rear shifter cable. The last three generations of Shimano shifters (the ones where the cable housing goes under the handlebar tape) are notorious for this. I have to replace my rear shifter cable every 2000 miles or so.
    But at 600 miles, I really doubt it's a broken cable. How much resistance do you feel on the shifter when trying to go to the large chainring?
    tlg
    tlg is offline
    May 2011
    Normal wear and tear.
    Shimano cables are notorious for fraying and breaking. Particularly 10sp and 11sp. (10sp was worse, 11sp is a little better) There is a tight bend inside the shifter. The constant movement over the bend causes the wires in the cable to weaken, fray and break.
    Usually the rear shifter goes more frequently since you shift more with the rear. It's typical for rear cables to fray/break in the 3k-5k mile range.
    tlg
    tlg is offline
    May 2011
    Ok, that's odd then. Not likely a broken cable.
    My $2 bet.... the pinch bolt wasn't tight enough and the cable slipped.
    [REDACTED]
    May 2014
    I bet you $2 that he didn't.
    Feb 2002
    That' my $3 bet.
    'brifter' is a lame word.
    That' my $3 bet.
    I'll see your $3 and raise you to $5.
    I work for some bike racers
    and a bunch of skateboards
    Aug 2018
    Pinch bolt. That is plausible. Cable snapped? Not so much.
    Rub it............
    Nov 2007
    Well have you checked it yet to prove one way or the other?
    Sent from my SM-G930V using Tapatalk
    Oct 2013
    How do you know how much he changes his front rings? I'll go with the the broken cable.
    If you ride rollers a lot, one uses the FD as much as the RD. ....almost.
    BANNED
    [REDACTED]
    May 2014
    600 miles is a stretch (no pun intended) even for a rear cable.
    Banned forever.....or not
    Aug 2002
    Sport's drink glue??? Do you slop sport's drink down the outside of the down tube???
    Dogbert.
    I>U
    Aug 2018
    Turns out, it's the shifter; it failed. They're just waiting for the a new shifter from Trek. Who knew?
    Sep 2011
    They are waiting on a shifter from Shimano. Trek does not cover that, Shimano does. Better stay on top of the shop on this one.
    [REDACTED]
    May 2014
    Unusual, but it does happen. Shimano is pretty good about warranty coverage. I bought a bike with a Shimano RS-11 wheelset. A year later, the bearings went south on the front wheel to the extent that the cup was scoured. Long story short, my shop convinced Shimano to give me a brand new wheelset - both front and rear so they would match!
    Quote Originally Posted by 202cycle View Post
    ^This^
  1. Front Deraileur Rubbing Chain on Trek 1500...
    By rickreyn in forum Components, Wrenching
    Last Post: 01-24-2009, 01:34 PM
  2. Front Deraileur problem
    By HANK in forum Components, Wrenching
    Last Post: 03-08-2005, 07:55 AM
  3. Compact Crank with Front Deraileur help
    By piercebrew in forum Components, Wrenching
    Last Post: 10-22-2004, 07:06 AM
  4. Compact Crank with Front Deraileur help
    By piercebrew in forum Cyclocross
    Last Post: 10-21-2004, 12:46 PM
  5. Record Front Deraileur Problem
    By JDCowboy in forum Components, Wrenching
    Last Post: 06-07-2004, 03:44 AM
