Front derailleur cage widths
Results 1 to 2 of 2
    Apr 2019
    Front derailleurs are sold as being for 'X speed' setups, assumedly because they use progressively narrower chains so work best with a matching width cage. When I bent the 8 speed that came on my bike I replaced it with an 11 while running a 9 speed chain on 8 speed crank/chainrings (I was planning on upgrading to 10 or 11 speed but changed my mind) and it works fine. I have no real reference as to whether it works well compared to a pricy Dura Ace but it's good enough.
    I'm posting this because yesterday I had to adjust it as there was an intermittent squeak which turned out to be the chain rubbing on the outside of the cage when in the small 3 sprockets at the back. I have a friction shifter so can trim but this made me wonder if I could trim less often if I had a wider cage?
    Any other disadvantages to using a 'too narrow' one would be interesting too.
    'brifter' is f'ing stupid
    I guess...but it's one of those things I've never thought about. Ride the bike.
    #promechaniclife
  1. Convert SRAM Froce rear derailleur cage plates to medium cage
    By youngmth in forum General Cycling Discussion
    Last Post: 08-07-2015, 01:31 PM
  2. Short cage or long cage derailleur?
    By attwyn in forum Bikes, Frames and Forks
    Last Post: 03-23-2015, 07:29 AM
  3. Sram Red Rear Derailleur Aero Glide short cage vs medium cage?
    By ZachUA in forum Components, Wrenching
    Last Post: 02-10-2014, 11:33 AM
  4. Rear derailleur short cage vs. long cage???
    By Roubaix29 in forum Components, Wrenching
    Last Post: 07-28-2010, 09:56 AM
  5. Long Cage vs Short Cage Derailleur
    By slyjackson in forum General Cycling Discussion
    Last Post: 05-06-2009, 10:10 AM
