Front derailleur shifting on rollers
Results 1 to 11 of 11
    What the what???
    Jul 2009
    I知 assuming it has to be operator error, but I have a bike with a front derailleur that shifts fine in the stand... fine on the road... but when I知 riding on rollers it will not shift into the big ring. I致e tried different combinations of speed and power before and during the shift, but no luck so far.
    Anyone else experienced this?
    Sent from my iPad using Tapatalk
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    'brifter' is a lame word.
    I've definitely seen that happen on trainers when riders are pedaling low cadence/big gear. Just happened yesterday...bike wouldn't go up to the big ring on the trainer, put it in the stand, no problem. On the road, no problem. Rollers...that's not happened that I can remember. I suppose you could be just a tiny big low on cable tension or the high limit is just a tiny bit tight.
    I work for some bike racers
    and a bunch of skateboards
    What the what???
    Jul 2009
    I値l try a little nudge to each and see if I can make it work. Thanks.
    Frog Whisperer
    May 2003
    What CX says with a reason. You are riding a vintage steel frame? If so, you definitely don't get the same frame flex as you would on the roads, you'd be on the floor with that much torque on the frame I bet. A 1/4 turn might be enough, not enough or too much. Give it a shot.
    Of course I'm sure...that doesn't mean I'm right.....
    "There's no sense being stupid unless you show it."
    What the what???
    Jul 2009
    Quote Originally Posted by Touch0Gray View Post
    Not steel for this one. Titanium.
    I had wondered if there was an odd spot where no resistance (in the stand) let it shift fine... and considerable resistance (on the road) let it shift fine... but the rollers maybe smoothed things out just enough to cause a problem???
    Sort of a 喪everse Goldilocks...
    Frog Whisperer
    May 2003
    Quote Originally Posted by Opus51569 View Post
    I use my track bike on the rollers, so I have no shifting problems, but I can guarantee that I ride FAR smoother and put FAR less torque on my frame, first of all, those aluminum clad tires have only nominal resistance on the aluminum rollers! (i actually built a magnetic resistance unit for them (under 7 bucks) and it made a HUGE DIFFERENCE, in my road readiness!
    Frog Whisperer
    May 2003
    Btw, Ti is not particularly stiff, imo, more "supple" than steel
    I find front shifts to the big ring on my smart trainer are harder than on the road. I have attributed that to the trainer continuing to provide resistance even when I ease up for the shift. However, I am not sure that same thing applies to rollers
    That kind of makes sense logically but I definitely am able to shift fine on the road even when I do so when soft pedaling (pedaling much slower than would be needed to catch up with how fast I'm going and tensioning the chain) yet there have been times when it's really slow on the trainer with more, or less, force being applied.
    I don't see frame flex having anything to do with it. Presumably you are not rocking the bike at all on both the road and rollers at least sometimes when you shift and any flex from your body weight on a straight up/down bike would be consistent between rollers and the road.
    It happens. I can't explain it. It also happens in the rear between the stand and the road (never had bad shifting only on the trainer when road when fine on stand and road were fine though)
    What the what???
    Jul 2009
    Yeah, I don稚 put a lot of sprint power down on the rollers. I知 rarely out of the saddle. Just spinning mostly.
    So far, I致e had good luck with the shifting from the rear derailleur. Only the front has given me problems.
    wim
    wim is offline
    Feb 2005
    Sometimes two things come together on rollers: Riders are reluctant to ease up on the pedals for the moment of the shift, and they don't move the shift lever as forcefully and quickly as they do on the road.
    The reasons are understandable: the wheels slow down their rate of rotation rapidly if you ease up on the pedals, and there's the concern of loss of control if you put force into the bars that could turn them.
  1. Replies: 5
    Last Post: 07-11-2012, 04:11 PM
  2. Parabolic Rollers vs. cylindrical Rollers with Bumpers
    By Solomon76 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 07-04-2012, 12:15 PM
  3. Rollers: Kreitler v E-Motion v Rocking Rollers ?
    By Lagavulin12 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 10-28-2009, 07:05 PM
  4. setting up rollers -- front roller axle vs front hub axle
    By teleguy57 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-03-2009, 06:39 PM
  5. Please Explain Shimano Front Derailleur Shifting!
    By Creelove in forum Components, Wrenching
    Last Post: 09-22-2004, 08:41 AM
