Frozen Bottle Cage Bolts
Page 1 of 3 123 LastLast
Results 1 to 25 of 61
    Nov 2014
    I realize there are a multitude of threads on my topic, however, I'm looking for a fresh look at my specific issue.
    I've come across an old Trek 5200 OCLV frame and it seems the previous owner did not have any grease most of the time.
    I got 1 bottle cage off without too much difficulty (yes you guessed it, the seat tube cage) almost getting to the point of rounding off the hex heads. The cage on the downtube was a different story. No luck with various length hex wrenches. I finally was able to secure visegrips on the bolts, but both bolt heads just snapped right off, leaving the remainder of the bolts stuck, frozen in the frame. I can see quite a bit of corrosion. If fact some of the corrosion seems to spread over nearby areas of the carbon tube.
    Do you think I have any chance of extracting the bolt remains, or has the corrosion simply fused bolt to the threaded receiver? I've been spraying WD40 on the bolt fragments, but as they fill the holes completely, I doubt whether any of this is getting to the threads, fused or not.
    Any tips appreciated.
    Quote Originally Posted by GKSki View Post
    No, I don't.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Your best bet is probably to drill out the remaining bolt and run a tap through it.
    Use a 4mm (5/32") or smaller bit and M5 tap.
    And if that doesn't work, drill out the insert and put in a Rivnut.
    Aug 2017
    I've not had great luck using WD40 as a penetrating oil. If you can find some, Kroil is great stuff. PB Blaster works less great, but still better than WD40 and readily available. Kroil draws into gaps really well, and will creep and flow everywhere, so don't get it on things you don't want loose. Also, I'm not sure how it will interact with the resin used in the frame and threaded inserts, so use at your own risk or maybe test it somewhere.
    You could try giving it a little penetrating oil every day for a few days, then try a left-handed drill bit. You should be able to find those at a hardware store, and definitely online. I have a set of LH bits and extractors. I'd say half the time the bolt comes out with the drill bit and Kroil. If not, on to the extractor.
    If none of that works, drill it out as tlg said.
    'brifter' is f'ing stupid
    PB Blaster or something like that. Then (most likely) a drill then an EZOut. Possibly a tap, maybe a new rivnut. If the hole is too big any Trek dealer can get you oversize rivnuts.
    #promechaniclife
    Nov 2014
    Thanks all for the great advice. I'm thinking the bolt and the female part have pretty much corroded together by now. I'll try the PB Blaster and patient workflow first before proceeding to surgery.
    Dec 2006
    Penetrant alone won't break the bond. After you let the fluid do its thing, rap the bolt with a hammer repeatedly for say 1-3 minutes. Never apply so much force turning the bolt to force it to move where you jeopardize the integrity of the bolt. Work it in BOTH directions, rocking back and forth. It may take hours, but patience is your tool.
    Nov 2014
    Peter, wish the bolt heads had not snapped off in the vise grips as your suggestion may have been the way to go.
    I have no bolt material remaining to get a purchase on.
    Reputation: Srode's Avatar
    Aug 2012
    Try SiliKroil - it's the best penetrating oil I've ever used. Pricey but it works better than the others IMHO.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    I have no bolt material remaining too get a purchase on.
    You might try using a thin punch, and tapping on the bolt "stud" using that.
    I'm not familiar with that model of Trek, are the mounts aluminum inserts? If so, it's my understanding from reading here that ammonia can help dissolve the corrosion you're dealing with. I've never had to do it, so can't speak first-hand, but trying couldn't hurt, before you have to drag out the tapset. Best of luck.
    Donald Trump has never had a wife he didn't cheat on.
    There are over 6.2 million covid cases in the United States (as of September 6th), eight months after Donald Trump said it was "totally under control," and that "it's gonna be just fine."
    Nov 2014
    Thanks, but I think ammonia may introduce a different set of problems and danger.
    I managed to drill through the bolts with a 5/64" bit and have tried using the screw extractor but no luck so far but I will keep trying.
    Oct 2013
    If you drilled through the bolt, just tap it and use a smaller bolt, done!
    BANNED
    tlg
    tlg is online now
    May 2011
    No don't do that!
    You don't want a smaller (weaker) bolt in compromised material.
    Just use the correct M5 tap.
    Nov 2014
    O.K. I know the bit I used to drill the hole through was 5/64 as that is what the screw remover paired with. To be honest, one hole seems centered while the other is a bit off center. Does anyone know what size bit is used before an M5 tap? Also, it's a fine M5, correct?
    M5 x .8.
    #promechaniclife
    Nov 2014
    Thanks, CX, that's the thread. Now what is the proper bit size to use before tapping?
    tlg
    tlg is online now
    May 2011
    post #3
    4mm (5/32") is the tap drill for M5.
    You can use a little smaller too, especially if you're off center a bit. The tap will clean out any remaining bits.
    Nov 2014
    Thanks, I'm all set now. Unfortunately one of the inserts is now a spinner from trying the screw remover. Guess i won't be able to tap that one unless I can keep it from moving.
    Dec 2006
    Can you hold it still enough to begin threading a bolt?
    What's usually done is, thread a nut on the new bolt and thread the bolt into the boss. Holding the bolt head stationary, tighten the "jam" nut against the boss. It should draw up the rivnut and secure it.
    tlg
    tlg is online now
    May 2011
    Now ya gotta get the insert out. Try drilling larger and larger one bit size at a time until it falls out.
    If it spins and you can't drill it, try a dremmel.
    Nov 2014
    Tapping was going well until the receiver started spinning. Any tips for getting the tap out.
    Nov 2014
    Any tips on dealing with the "spinner" remaining? The other one came out wiggling to get the tap out. Wasn't good for the carbon tube though. Does it look that i will be able to put a rivnut in the hole?
    Oct 2013
    I would have put a bottle cage on with a stainless steel pipe clamp before I did the disaster that I see.
    BANNED
    Dec 2006
    You can always go up one size on the bottle cage bolt, to a 6mm. That would mean using a slightly larger rivnut, which might fit the hole better. And you would only need to modify one hole. Leave the other hole as-is.
    What's the hole measure? A 5mm rivnut requires a 7mm hole; a 6mm rivnut requires a 9mm hole. As a rule, always try the smaller size first, before making permanent modifications to the hole.
    As for removing the remaining rivnut; you've obviously got to get a purchase on the remaining rivnut flange. I would try applying a strip of duct tape over the rivnut. Then use a Dremel tool with a tapered bit to grind it out. Or you could use a small round file and file down through the rivnut, which wouldn't spin the rivnut at all.
    Nov 2014
    I was able to Dremel the 2nd flange out, , so one exit was rough and this one went pretty smoothly in the end, although now I have to pull the bottom bracket to get the piece out.
    I put calipers on the 2 remaining holes and they are roughly 9mm. I also measured the existing flanges on the seat tube and those had an OD of 11mm.
    I'll have to learn more about finding the right rivnut (probably will have to be a 6mm) and how to install. I'm guessing my pop riveter will not be suitable for the job.
  1. source for extra-long bottle cage bolts?
    By Bob Ross in forum Components, Wrenching
    Last Post: 12-23-2007, 07:25 AM
  2. anodized bolts/Ti bolts... bolts in general...
    By Cruzer2424 in forum Components, Wrenching
    Last Post: 02-16-2007, 06:56 AM
  3. Drink bottle cage bolts and rust
    By WingNut in forum Components, Wrenching
    Last Post: 12-05-2005, 12:49 AM
  4. What bottle cage bolts?
    By BugMan in forum Components, Wrenching
    Last Post: 10-02-2004, 05:38 PM
  5. Water Bottle Cage Bolts--what size are they?
    By mk_42 in forum Components, Wrenching
    Last Post: 06-09-2004, 11:59 AM
