FSA Expander Plug
Results 1 to 4 of 4
    Jan 2016
    FSA Expander Plug
    I have this expander plug.
    https://www.biketiresdirect.com/prod...iABEgIUHPD_BwE
    A friend of mine told me not to use it as it does not contact enough of the steerer tube of my fork and my stem could crush the steer tube. Is he right that this is an issue? I have the stem positioned so that the expander plug rests inside the part of the fork that the stem clamps to, but it is not long enough to support the entire stem, only about 3/4 of it.
    Reputation: nova_rider's Avatar
    Sep 2005
    Just carefully tighten down the stem bolts to the correct torque value and it should be fine. I have the same expander plug.
    'brifter' is a lame word.
    There are thousands and thousands of those in use, if they were a problem we'd know about it. Are there better ones available...sure. Are you going to crush your steerer? You'd have to try pretty hard. Sounds like your friend isn't hugely knowledgable about this kind of thing.
    I work for some bike racers
    and a bunch of skateboards
    Nov 2014
    I have a very similar one on a Bianchi using an FSA headset. What is your bicycle?
  1. Replies: 4
    Last Post: 10-23-2007, 12:07 PM
  2. 585 build question - expander plug
    By oneslowmofo in forum Look
    Last Post: 05-06-2007, 05:02 AM
  3. using an expander/compression plug in an aluminum steerer?
    By longcoolmother in forum Components, Wrenching
    Last Post: 04-05-2007, 11:43 PM
  4. Expander Plug?
    By tmluk in forum Colnago
    Last Post: 03-03-2006, 10:08 PM
  5. Carbon steerer and expander plug question: how to remove?
    By Old_school_nik in forum Components, Wrenching
    Last Post: 05-23-2005, 11:20 AM
