Glueless Patch Failures - Page 3
Page 3 of 3 FirstFirst 123
Results 51 to 64 of 64
  1. #51
    Oct 2013
    You're not in charge of this thread! ...I'm taking over!
    You haven't been around if you never had a new tube with a 3" slash in it at a seam straight out of the box.
    BANNED
  2. #52
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    It just seems, to me, that throwing all these co2 cartridges, once flatted tubes and elephants into the land fill is just a big waste.
    Co2 cartridges are steel. They can and should be put out with your regular recyclables.
  3. #53
    Reputation: velodog's Avatar
    Sep 2007
    I've been patching tubes for years. I have tubes with multiple patches. I've never, not once had a glue on patch fail. They are permanent. There is no risk.
    Now... I have had brand new tubes, right out of the box fail. I'd say there's more risk using a new tube.
    Yep, a patched tube is a known entity whereas the new tube is an unknown, only expected to be in good order. And it's this reason why a patched tube is preferred to be used as a spare by some.
    Too old to ride plastic
  4. #54
    Sep 2007
    No argument here.
  5. #55
    JSR
    JSR is offline
    Feb 2006
    So stick a spare in and patch the tube when you get home, pump up the tube to check your work and carry it for use in your next flat. I still don't see the risk.
    And what about a bad day that brings 2, 3 or more flats, how man tubes need be carried before the ride can be considered risk free.
    Iím right with you, up to a point. A punctured tube that already has a patch clearly has bad juju. It needs to be culled from the herd.
  6. #56
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    But what about the CO2 that will eventually rise into the atmosphere and contribute to climate change?
    "With
    -- DCGriz, RBR.
  7. #57
    Oct 2013
    Do U drive a car, fly in a plane, get mail, go to a store, on and on, that's where all the co2 is coming from, not a little co2 charger.
    BANNED
  8. #58
    Banned Sock Puppet
    May 2014
    Understood. I guess I needed an emoji in there to clarify it was a tongue in cheek remark. Kind of like the difference between throwing a bike tube and an elephant into a landfill.
    "With
    -- DCGriz, RBR.
  9. #59
    tlg
    tlg is offline
    May 2011
    I dunno.
    But IF you're using a co2 cartridge it makes zero sense to put it in a landfill.
  10. #60
    Sep 2007
    Quote Originally Posted by JSR View Post
    Superstition. Talking about flats doesn't cause flats either.
  11. #61
    tlg
    tlg is offline
    May 2011
    Do you throw away the tire too, since the puncture passed through it into the tube. Bad juju started with the tire.
    In fact, probably should throw away the whole bike, juju and all.
  12. #62
    Banned Sock Puppet
    May 2014
    There you go. Another excuse for n+1!
    "With
    -- DCGriz, RBR.
  13. #63
    Banned Sock Puppet
    May 2014
    No, but wishing flats on someone else.........oh, never mind.
    "With
    -- DCGriz, RBR.
  14. #64
    jta
    jta is offline
    Jun 2012
    Update:
    Based on suggestions on this thread, I pulled the offending glueless patch off the puncture, carefully cleaned and repatched the puncture using a patch from a newer patch kit. Seems to have worked fine and running it on a rear tire. I was going to use a Rema patch kit, but the liquid vulcanizer dried up after years of disuse.
    Iíll continue carrying a spare tube and patch kit, but now will replace the tube on the road and save the punctured tube in case I get another flat. Will also change the patch kit every season as the older patches donít seem to adhere as well (chemically change over time as someone pointed out). Seems like everyone has some kind of redundancy built into what they carry for the rare bad day.
    BTW, amazing what you can get into a ride case that fits into one jersey pocket these days: tube, patch kit, boot, lever, multi-tool and torque bits with room to spare. iPhone, ID, credit card and cash goes into a Sealine waterproof case that fits neatly into a second jersey pocket.
  1. Tubes----the old dilemma: to patch or not to patch?
    By BelgianHammer in forum Wheels and Tires
    Last Post: 02-14-2015, 05:40 PM
  2. Tube Patch Glue Spread,Drying Time, Patch Pressure.
    By TomBrooklyn in forum Components, Wrenching
    Last Post: 09-08-2008, 11:51 PM
  3. Patch kits - glueless or no?
    By rugger in forum Wheels and Tires
    Last Post: 06-29-2006, 08:12 AM
  4. Patches - glueless?
    By Mudman in forum General Cycling Discussion
    Last Post: 08-04-2004, 12:56 PM
  5. Does anyone make a good glueless patch kit?
    By Matno in forum General Cycling Discussion
    Last Post: 04-27-2004, 12:35 PM
