Having a hard time finding a silver stem.....
Results 1 to 9 of 9
    Riding towards Delmarva.
    Reputation: RedRex's Avatar
    Oct 2004
    I've found plenty of stems with 1 1/8 clamp, I want 1inch, and....
    four bolt face plate
    1 inch steerer tube
    silver
    90 or 100mm
    5-7degree
    I sure wish the Nitto stem wasn't 1 1/8.
    Anything out there? This is for a very sexy custom steel frame, so those Profile stems seem sort of out-of-place.
    Apr 2004
    Just get a spacer, most 1 inch stems aren't even just 1 inch they are simply 1 1/8 with a shim.
    K
    Oct 2004
    No way man. I'm not putting a shim in there and klunking up my custom engraved top cap. I have a shim on my beater, and that just isn't good enough for my custom rig.
    I'll keep my black Ritchey stem if I have to, but there HAS to be a silver 1 inch stem.
    toomanybikes
    Guest
    Contact Sacha White or Sam Whittingham and get the stem made. You will get a custom, one off worthy of the finest bike, it will have the exact size and angle you want. You'll spend about $100 I would think.
    Sacha is at vanilla.com and Sam is at timetogetnaked.com
    good luck.
    Oct 2004
    "Sacha is at vanilla.com and Sam is at timetogetnaked.com"
    Nice info, thanks. One Santa heads back to the North Pole I will look into this for sure. 100 bucks seems logical for this rig, considering what I paid for my Nitto cages!
    Thanks.
    toomanybikes
    Guest
    Quote Originally Posted by RedRex
    Thanks.
    Sorry
    Vanillabicycles.com
    Sam is either timetogetnaked.com or fortebikes.com ( he has to change his name because of a certain large retailer)
    Reputation: Nessism's Avatar
    1 inch steerer tube
    silver
    90 or 100mm
    5-7degree
    I don't think you are going to find anything that meets all your requirements. 4 bolt faceplates are a fairly new fad that seem to only come in the 1-1/8" varity.
    Ritchey used to make the Comp model in a gray/silver color w/1" clamp - two bolt clamp though. Performance sold them among others. I actually prefer the Comp over the WCS because it's stouter and the face place doesn't make so much noise.
    Good luck.
    May 2004
    T H O M P S O N.
    Like the other posters have said, you probably won't find a 1" steerer clamp. (Almost) nobody makes one. You'll have to use a shim, in which case, you should get a Thompson.
    "I've courted brain damage like some courtesan of darkness."
    -The Good Doctor
    Oct 2004
    After looking at the images on the Vanilla site, that may actually be an appropriate direction. Maybe I can get a custom silver stem with blue "Vanilla" inscription to match my panels.
