Having some seroius issues and could use some help.
Results 1 to 4 of 4
    Jack of no trades
    Reputation: Wood Devil's Avatar
    Apr 2011
    Question Having some seroius issues and could use some help.
    I've got my CAAD set up on the Kickr. It's been the designated trainer bike for the past three years. Today I decided to change out the chain, cassette, and BB30 bearings, as each had over 6000 miles on them and a good six months worth of hard Zwifting.
    So I throw all the new stuff on this morning, as I've done dozens of times before. But this time I am experiencing significant vibration on the 15 through 11 cassette sprockets. Shifting is spot on through the full range of the cassette, but it is noticeably rough in those last few gears.
    I have no idea what is going on. I've tried three different cassettes, two chains, and even threw my Cervelo on the Kickr and it's the same thing.
    Anyone have any suggestions on what I should look at? The bearings have been pressed in nice and snug and torqued to the 39 - 41nm spec. I've focused in on the skewer and have made sure it is tight and that the bike is secure in the Kickr. I just can't figure this one out.
    I'm looking at the removable part for the Kickr (on the non-drive side) that skewer slides through, the through axle adapter. It's a little black part that has M135 and R130 markings on it, and I'm assuming that R130 is road specific and works with my CAAD9, and that the R130 marking should should be facing outward, correct? I'm pretty sure that's how it was in before, but so I'm not sure what the confusion is now.
    Jack of no trades
    Apr 2011
    Here's a video of the noise...
    https://youtu.be/LZi22tvW1Gk
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Have you tried riding the bike outdoors or another bike with the same setup? That would confirm it's either the bike or the trainer.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Slowski
    Reputation: eboos's Avatar
    Mar 2011
    R130 should be visible if using a 130mm rear axle hub (rim brake road wheel). M135 should only be visible if you are using a 135mm rear axle hub such as a disc brake road/cross wheel, or a mtb.
    I had issues with ghosting of the freehub on my Kickr and had to replace the inner freehub spacer which got crushed narrower. That didn't effect my shifting though. Is the axle fully seated in the dropout? If you switched bikes and the problem continues, the problem lies in the Kickr somewhere.
  1. I'm having some issues with my BB30
    By Wood Devil in forum Components, Wrenching
    Last Post: 12-04-2017, 10:22 AM
  2. What's the use of having them if you don't use them?
    By Turtleherder in forum Politics Only
    Last Post: 12-22-2016, 11:39 AM
  3. Working on a display, could use some help
    By crossracer in forum Retro-Classic
    Last Post: 03-08-2015, 02:09 PM
  4. Could really use some TREK help...
    By plasticmorph in forum Bikes, Frames and Forks
    Last Post: 08-04-2012, 07:12 AM
  5. Could use some help from Outlook experts...
    By JChasse in forum The Lounge
    Last Post: 11-18-2011, 07:14 AM
