Help! - which ferrule to use for Omega X brake?
Results 1 to 4 of 4
    Aug 2018
    When installing Omega X (front) with standard back plate I found that a ferrule coming with Shimano 5mm road brake cable does NOT fit into the cable hanger opening/slot. The ferrule is 6.0mm outer diameter, while the opening/slot in Omega X is about 5.6mm diam. Do you know which ferrule fits Omega X? Is it Ok to skip the ferrule? Just in case -- the bike is 2015 Felt AR3 with 6800 mech, used for DL Tri and crits. Thanks!!
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Skip the ferrule. Quite a few brakes on the market don't require a ferrule
    Sent from my SM-G930V using Tapatalk
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Feb 2002
    Quote Originally Posted by vladi View Post
    Use the ferrule if it fits. Use bare casing if the ferrule doesn't fit. Applies to both brake and derailleur cable casings.
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    If it doesn't fit, you must omit.
    Donald Trump has never had a wife he didn't cheat on.
    "Oh my god. This is terrible. This is the end of my presidency. Im fd.
  1. Shimano STI Brake Housing Ferrule?
    By Mad Cow Disease in forum Components, Wrenching
    Last Post: 11-01-2017, 05:30 PM
  2. When to use a brake ferrule tongue?
    By k9taxi in forum Components, Wrenching
    Last Post: 05-23-2015, 12:25 PM
  3. Brake Ferrule stuck...
    By xeon in forum Components, Wrenching
    Last Post: 06-16-2014, 10:49 AM
  4. Need for cable cap/ferrule on brake cable?
    By DaveG in forum Components, Wrenching
    Last Post: 09-27-2012, 12:59 PM
  5. rusted stuck brake cable ferrule
    Last Post: 06-04-2007, 05:54 PM
