How can I run an 11-40 cassette on my gravel bike?
Results 1 to 4 of 4
    Reputation: pulser955's Avatar
    Apr 2009
    I just got a Giant revolt advanced 2 with 105. It comes with a subcompact crank and an 11-34 cassette. I need to change the crank from a 170 to 172.5. I have one that is a normal compact crank. part of my problem is that at the moment I don't have a loot of gravel and more road to get to gravel. I want to get higher top gear on road and not lose my low gear for climbing. I was thinking abut the Wolftooth Roadlink DM with an XT mountain cassette. https://www.wolftoothcomponents.com/...ts/roadlink-dm IM wondering if anyone has any experience with it. Or a better idea?
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    I am running an 11-40 with the 105 rear derailleur no problem (32/48 rings). It has a little too much chain, but that is not a real problem if you are never in 32/11.
    I am just running the derailleur straight, no extra link parts.
    It is also on a Revolt 2.
    Oct 2017
    If your cranks are otherwise the same, you can swap the chainrings.
    In 48/11 at 90 rpm with a 700x28mm tire, you are going 31mph.
    Does this happen enough on the way to/from your gravel rides that you want to go to bigger rings? Going up to 50/11 only gets you to 32.5mph.
    I run a 48/32 with a SRAM 11-36t cassette on my dedicated gravel bike (RX 800 Di2 rear derailleur has no trouble with this). It gets me up Heart Attack Hill without me having a heart attack. I'll call that a success (considering my weight and age).
    Sent from my Pixel 3a using Tapatalk
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    Is your lowest set of gears really not low enough to get you up the worst hills? You have 34/34 which is 1:1.
    You could do what Rideit recommends, but if you make a mistake and go too far toward small/small, you could get some nasty ghost shifting. Hardly catastrophic. Just make sure you have enough chain wrap for large/large so you don't rip your derailleur off your frame. That WOULD be catastrophic.
  1. Can I run Ultegra R-8000 Short Cage Derailleur with a 11-32T Cassette
    By jsebastianorozco in forum Components, Wrenching
    Last Post: 05-31-2019, 04:43 AM
  2. Can I run 11-26 cassette with 50/34 crank - Shimano 105
    By MorganRaider in forum Components, Wrenching
    Last Post: 10-15-2010, 08:05 AM
  3. Can't find "sweet spot" with new cassette 11-26. Used to run 11-23
    By Bry03cobra in forum General Cycling Discussion
    Last Post: 08-26-2008, 12:56 PM
  4. Can you run an 11-21 9 speed cassette with an Ultegra Triple Crank?
    By mwilcko2 in forum Components, Wrenching
    Last Post: 01-04-2006, 06:02 AM
  5. Run-Bike-Run-Bike-Run
    By breadrunner in forum General Cycling Discussion
    Last Post: 04-30-2004, 02:03 PM
