How Do KMC ‘Stretchless’ chains Work?
Results 1 to 25 of 26
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    In other words, if they don’t ‘stretch’, how does wear manifest itself?
    Seems too good to be true.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Chains don't stretch. The inside of the roller wears causing elongation of the chain as it is pulled tight.
    https://www.sheldonbrown.com/chains.html
    Cyclists often speak of chain "stretch", as if the side plates of an old chain were pulled out of shape by the repeated stresses of pedaling. This is not actually how chains elongate. The major cause of chain "stretch" is wear. (See our article on chain wear for more details.)
    https://www.sheldonbrown.com/chain-wear.html
    Sounds like "Stretchless" is a gimmick. Maybe they figured out how to lengthen the life of the inside of a roller as it wears.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    What the what???
    Jul 2009
    From the KMC site- FAQS - KMC Chain
    "Our chains also feature our XXSP stretch proof treatment. This is a treatment that we have perfected in our years of chain manufacturing. The stretch proof treatment is a process of heating and cooling the steel alloys to certain temperatures to yield only the strongest and hardest steel."
    But perhaps more telling is the fact that on the same FAQ page, KMC says they only warranty their chains for manufacturers defects and they handle all other claims on a case by case basis...
    The Law of Headwinds states: If the ride out is easy... wait.
    Reputation: nova_rider's Avatar
    Sep 2005
    Quote Originally Posted by rideit View Post
    Where did you see this?
    Reputation: velodog's Avatar
    Sep 2007
    Forever Chains, throw away your rulers.
    Too old to ride plastic
    Oct 2013
    I'll have to change my will again, that chain is going to last more than one!
    BANNED
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Does DeBeers make Good Chains?
    'brifter' is a lame word.
    Roller wear, pin wear, bushing wear. Chains 'elongate' not stretch. If the plates actually stretched the holes for the pins would get bigger and everyone's chains would fall apart. Cables don't stretch either.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2005
    Yup, all of that is 120 year old news...but how are they marketing this as a ‘new’ thing?
    Seems hinkie.
    Reputation: Oxtox's Avatar
    Aug 2006
    only use KMC chains (X10SL) and they routinely last 8-10K miles.
    satisfied customer.
    Reputation: Lombard's Avatar
    May 2014
    Chain lube debate coming.....5.....4.....3....2.....1.....
    Feb 2005
    And the answer, of course, is Pro Link Gold.
    Seems hinkie.
    Probably like the new SRAM AXS chains, they're supposed to last a loooong time due to how hard they are. We'll see.
    May 2014
    But as always, YMMV.
    Oct 2013
    Well if they start making chains harder.... guess what... your chainrings & cassettes are now the wear item.
    BANNED
    Unless you also harden them and change the shapes a little bit. And...if the chain doesn't wear how will the cogs and rings wear? You need to have chain wear to have wear on the other parts. Like I said...we'll see.
    Sep 2007
    Not to stretch a point.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by Opus51569 View Post
    [I]"Our chains also feature our XXSP stretch proof treatment. This is a treatment that we have perfected in our years of chain manufacturing. The stretch proof treatment is a process of heating and cooling the steel alloys to certain temperatures to yield only the strongest and hardest steel."
    They also say:
    "KMC’s eXtreme Stretch Proof treatment of pins and plates makes this chain less susceptible to wear caused by sand or dirt entering the chain bearings."
    The telling point "less susceptible to wear. Which means they "are" susceptible to wear. Thus... not stretch proof but "stretch resistant".
    Sep 2007
    They also say:
    Marketing speak.
    Most highly, if someone doesn't understand that they probably don't think about their chain anyway. At least until it's so noisy that they can't even carry on a conversation, or a shop mechanic tells them that the drivetrain is wore out and it all needs replacing.
    gazing from the shadows
    Jan 2003
    More slowly?
    Friction exists.
    Asymmetrical friction exists for each and every tooth.
    May 2014
    Quote Originally Posted by QuiQuaeQuod View Post
    More slowly?
    Friction exists.
    This is what I was thinking. Metal against metal, one or both surfaces must eventually lose material.
    Feb 2002
    Seems hinkie.
    That's because, in a word, it is.
    Sep 2005
    It's more like metal against grits against metal. Metal to metal only exist perhaps for the first 100ft of a ride on a brand new chain. Encase the entire drivetrain in oil would certainly prolong the life of mechanical components, but that is not exactly practical for bicycles and cyclists.
    May 2014
    Quote Originally Posted by nova_rider View Post
    Grit certainly doesn't help, but most of that gray "dirt" you wipe off your chain are fine metal fragments that came off your chain, cogs and rings.
    Feb 2002
    Beg to differ. When I ride the rollers during the winter, I put on a couple of thousand miles and the chain develops minimal black gunk, doesn't need lubrication (remains quiet and smooth), and wears very little. My dedicated roller bike has over 10K miles on the chain indoors and it had a full outdoor season on it before it became a roller bike.
    Out on the road, I need to do my home brew clean-lube routine every 350-400 miles before the chain starts making noise. It is the road grit that is the source of the black gunk and therefore the primary cause of wear.
  1. KMC 11SL chain and KMC Missing Link?
    By ejr13 in forum Campagnolo
    Last Post: 01-17-2011, 12:25 AM
  2. Sram chain link won't work with KMC and DA chains...I think
    By dasho in forum General Cycling Discussion
    Last Post: 02-29-2008, 06:41 AM
  3. KMC chains and cassettes
    By mercurymike in forum General Cycling Discussion
    Last Post: 01-09-2008, 09:38 AM
  4. KMC 10-speed chains $22 @ Performance
    By drewmcg in forum Hot Deals
    Last Post: 08-07-2007, 04:01 AM
  5. KMC Gold Chains
    By Ricky J in forum Components, Wrenching
    Last Post: 02-11-2007, 05:58 PM
