How to measure disc brake pad thickness
Results 1 to 14 of 14
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Are folks using any special caliper or fancy digital tool to measure pad thickness, or just a ruler, or just eyeballing things?
    When you measure, are you taking the pads out of the brake (seems like pain)? Or just stick a flashlight on them to see better?
    I'm on TRP Spyres... minimum thickness is supposedly 0.8 mm. New pads start around 2 mm, and it looks like I'm down to about 1 mm. Should I just go ahead and change them or squeeze some extra miles?
    Interestingly, and I could be totally wrong if I'm measuring poorly, looks like my back pads are a hair thinner than front, totally opposite of what I'd expect.
    For the record, mixed terrain riding, a few wet rides but not a ton, definitely some steep descents where the brakes are used a lot, took about 700 miles over 15 months to get from 2 mm to 1 mm.
    Nov 2013
    I think you're over-analyzing this. Pull the pads and if they're getting thin, replace them. Heck, you're going to be replacing them no matter what, order some new ones, put 'em on, and enjoy riding this Spring w/o worrying about your brake pads.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by jetdog9 View Post
    I've never measured pads. Road or MTB. When they look thin I replace them.
    That's weird. I've never seen that.
    Perhaps they were dragging?
    'brifter' is f'ing stupid
    Eyeball it. If it looks like the friction material is close to being the same thickness as the pad spring replace them. If you use the back brakes much they'll wear more than the fronts because they do so little to slow you down...so you use them more. But they don't do anything (really) so they just wear out. The fronts have much more affect so you can slow more while using them less.
    #promechaniclife
    Neophyte
    Jul 2007
    Thanks, folks
    Sep 2011
    Hint: the thickness of most credit cards is about .77-.78 mm thick.
    Reputation: Srode's Avatar
    Aug 2012
    A feeler gauge next to the pad will give you a good idea if you don't like eyeballing them, or you could measure the pad and backing then just the backing with a caliper and subtract one from the other. I would just eyeball them like everyone else said though.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    Next new product from KMC...Disc Pad Only Calipers!
    $90 shipped, special deal for you!
    Nov 2002
    How about these pads?
    My last two rides were down Mt Diablo. Never expected these pads to wear out so soon. The front brake started to get overly noisy, which clued me in. Probably belongs in CX's hall of shame.
    Nah, those are still good. When you can see through 'em you know they're worn out...
    #promechaniclife
    tlg
    tlg is offline
    May 2011
    Those are the new vented pads
    Russian Troll Farmer
    Sep 2016
    0.8mm is roughly .030". Take a .030 feeler gauge. Engage caliper. Slide feeler between disc and backing plate. If it goes, it's got more than 0.8mm.
    "L'enfer, c'est les autres"
    Neophyte
    Jul 2007
    That makes sense... hadn't thought about a strategy like that.
    Sep 2016
    It's what every auto mechanic has done since disc brakes were first invented.
  1. Replies: 3
    Last Post: 10-29-2019, 02:45 PM
  2. road disc brake pad and rotor life span?
    By deadleg in forum Components, Wrenching
    Last Post: 12-07-2018, 09:06 AM
  3. Replies: 27
    Last Post: 04-23-2017, 04:57 PM
  4. Disc brake pad wear
    By Rogus in forum Components, Wrenching
    Last Post: 06-29-2015, 12:14 PM
  5. Are there different thickness brake nuts?
    By DIRT BOY in forum Components, Wrenching
    Last Post: 08-30-2008, 07:24 PM
