How much seat post extended is too much seat post
Results 1 to 9 of 9
    May 2006
    When do you look at a seat post and realize that it is too long? Road Bikes.
    Feb 2005
    There is usually a line on the post that tells you the how much post you can have above the seat collar or how little you have still in the bike.
    if not marked...
    As already noted, the post shold have markings for max. height. If it doesn't then one rule of thumb is that the end of the post should be below the bottom edge of the top tube.
    Carbon posts are usually marked at 6-7cm from the end.
    century rider
    Apr 2002
    I guess...
    what the OP wanted is how much cm of seatpost should be sticking out on a traditional road bike not considering the markings( could be mtb post). i'm curious too.
    Cannot bench own weight
    Reputation: Einstruzende's Avatar
    Jun 2004
    Well I recall seeing some pictures of a couple in the thread called "Show us your Taiwan and Chinese..." (something like that).
    Too much seatpost = undersized bike. Perhaps that's what the OP is after.
    Resident Dutchbag
    Reputation: rogger's Avatar
    Aug 2005
    Quote Originally Posted by Einstruzende
    That depends on how much drop you can take, pros ride ridiculously small frames to be able to get the desired drop.
    Originally posted by thatsmybush:
    I can only speak for my self, but if Fergie wanted to rub her lovely lady lumps on me, I could play the role of "human stripper pole."
    May 2006
    Clarification
    Now we are getting to what I am after. Clarification: when do I look at how much the seat post is extended and realized that my bike is undersized?
    What the Hell is going on
    Reputation: JaeP's Avatar
    Mar 2002
    My race bike
    That depends. I have a XL Fastback comp with a 410mm Thomson mtb seatpost. 220mm of seatpost is exposed. Others have told me I have a scary seatpost. I dunno. I like it.
    Here's a link: http://forums.roadbikereview.com/sho...13932#poststop
    You'd think we were here for something other than fun. - Ishmael
    fmw
    fmw is offline
    Sep 2005
    Don't forget that many frames these days have a sloping top tube. Those frames will expose more seat tube than a traditional one. It's better to look at the vertical distance or drop between the saddle and the handlebar.
