How to remove hydraulic brakes?
Results 1 to 3 of 3
    Witty custom user title
    Reputation: E 12's Avatar
    Jul 2008
    Probably a stupid question, but I need to remove a set of hydro brakes from an internally routed frame (selling them along with a group set and going a different direction with this build). Anyway, where do I disconnect the hoses? At the levers? Do I need to tape off the hoses before pulling them through the frame? Anything special i need to consider so I don't make a huge mess or screw up the brake set?
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by E 12 View Post
    You can disconnect it at the lever or the caliper. Doesn't matter. Which ever end is easier to pull through the frame. You'll probably have to cut the olive off. The nut won't fit through most internally routed frames.
    Drain all the fluid out. Blow some air (gently) through the hose to get most of the remaining oil out. It shouldn't be too messy. I've done it without taping the hose. It's no big deal.
    If you're selling it, the buyer is going to likely need new hose. Or replacement olives for the ones you cut off.
    Reputation: nova_rider's Avatar
    Sep 2005
    Make sure to attach a pull string to the rear hose if you're pulling it out.
    Sent from my Lenovo TB-8705F using Tapatalk
  1. Shimano Hydraulic ST-RS685 or Sram Hydraulic
    By Kuna in forum Cyclocross
    Last Post: 07-24-2015, 05:43 AM
  2. Replies: 49
    Last Post: 08-10-2012, 10:14 AM
  3. SRAM Red Hydraulic Shifters and brakes
    By DIRT BOY in forum Components, Wrenching
    Last Post: 02-21-2012, 11:10 AM
  4. Is there such a beast? - hydraulic disc brakes for roadbikes?
    By fisherman in forum Components, Wrenching
    Last Post: 02-17-2006, 01:06 PM
