How would you remove corrosion?
Results 1 to 14 of 14
    Tourist
    Reputation: Pierre's Avatar
    How would you remove corrosion on the Honjo fender in the photo? Some unknown but very corrosive liquid fell on some parts of a bike. How would you restore this to some kind of shiny state? For the rust on the Tubus rack I already found a solution, I sanded it lightly with 400 grit paper, it worked fine and didn't noticeably make the spots too shiny. I don't know how to deal with the fender though. Thanks!
    Oct 2013
    Is that fender alum? if so just sand it too, maybe with steel wool final .... you'll probably want to spray coat it with clear coat.
    BANNED
    Tourist
    Yes it is aluminum. Online search seems to indicate bronze wool (slightly better than steel wool) then metal polish. Somewhere else I read to use cream of tartar.
    Apr 2011
    I've heard and seen videos of using cola to remove surface rust. Maybe a small portion can be tested.
    What the what???
    Jul 2009
    Quote Originally Posted by bvber View Post
    Vinegar works, too. It smells worse, but isnít as sticky.
    Sent from my iPad using Tapatalk
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    I was "social distancing" before it was cool.
    Reputation: velodog's Avatar
    Sep 2007
    I thought navel jelly and scotch bright pads and happened upon this. Might be some suggestions worth pursuing. My Honjo's have developed dull spots, but nothing like that.
    Removing Oxidation From Aluminum - Moderated Discussion Areas
    Too old to ride plastic
    Aug 2017
    I've used steel wool, then polish. I've made a paste with baking soda and used that before. A convenient, ready made compound is toothpaste. Make sure it's not a 'gel' type toothpaste. It might be tough to match the dull matte finish; you may have to play around a bit.
    As duriel mentioned, some type of coating after polishing helps delay the oxidation's return.
    Done
    Mar 2002
    Quote Originally Posted by Pierre View Post
    Don't put steel wool or sandpaper on that finish. And don't spray it with a clear coat.
    Do use Wenol Red (in a tube) or Nevr Dull (cotton wadding) metal polish, a soft cloth, and lots of elbow grease. Or use auto rubbing compound. When you get it to a finish that you like, put some automotive wax on it. Yes, you will need to polish it up from time to time, but spraying with a clear from the hardware store to keep it from going dull is asking for trouble.
    If you have access to a cloth buffing wheel and a bench grinder, even better.
    It's Been Fun...See You Down The Road.
    Reputation: Srode's Avatar
    Aug 2012
    Never Dull works great polishing aluminum. It's not going to get rid of heavy pitting, you would need to wet sand that smooth I think, with 1000 or ultrafine (2000) grit sand paper before the Never Dull (if it's pitted). Not a fast process but it would get it where you want it I think. I fought many an aluminum mag wheel with that stuff years ago. If you get too much shine running over it with 000 steal wool would do the trick I think.
    I like the idea of using a buffing wheel on a grinder but you REALLY need to be careful with that - if it grabs the fender it can do a lot of damage to the fender, you, or anything in the area when it takes off.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Done
    Mar 2002
    Polishing old mags? Cool!
    You are right that Nevr dull won't get rid of pits. I was trying to suggest something that would give the OP a shot at salvaging the existing brushed finish on the fender and not end up with a mottled finish. Personally, I'd just clean it up and ignore the pits - you won't be able to see them from 5 feet away.
    The other complication is that the fenders probably (just a guess) have a clear anodizing to prevent corrosion - if you bring out the big guns you pretty much have to remove all of the coating to get a uniform look.
    You are also 100% right that a buffing wheel is one of the quickest ways to ruin a piece of metal. I've had mine snatch crank arms out of my hand and fling them across the garage. It is a light touch - let the compound do the work.
    Sep 2007
    Or leave as is.
    Beausage=honest wear from using the bike.
    Tourist
    That Nevr Dull product is AMAZING ! I used 400, 600 and 1500 sandpaper on the big damage (because that's what I had at home). Then a metal polish liquid from Home Depot called Basso. And then Nevr Dull.
    But really, the star of the show is that Nevr Dull. I was expecting wax-type abrasive that I would apply - instead, I see this cotton full of stuff. Rubbed it and rubbed it and rubbed it, and when I wiped the liquid, the fender was all shiny! So much that I had to do the polishing on the front fender as well, even if it was not corroded.
    I'm not skilled at it and to be honest I don't care all that much about perfection here, but already the result is way better than what I was expecting (see photo). Thanks a lot!
    Aug 2012
    But really, the star of the show is that Nevr Dull. I was expecting wax-type abrasive that I would apply - instead, I see this cotton full of stuff. Rubbed it and rubbed it and rubbed it, and when I wiped the liquid, the fender was all shiny! So much that I had to do it on the front fender as well, even if it was not corroded. I'm not skilled at it and to be honest I don't care all that much about perfection here, but already the result is way better than what I was expecting (see photo). Thanks a lot!
    Oh Wow! That' really turned out nice!!
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Or leave as is.
    Not to mention that thieves will leave it alone.
    "With
    -- DCGriz, RBR.
  1. Replies: 15
    Last Post: 07-08-2011, 07:59 PM
  2. What would cause rear derailleur adjustment everytime I remove the wheel?
    By roadbike_moron in forum Components, Wrenching
    Last Post: 07-22-2010, 03:56 PM
  3. Replies: 89
    Last Post: 08-28-2009, 06:03 AM
  4. Would you run this light? Would you ride here?
    By MB1 in forum General Cycling Discussion
    Last Post: 05-05-2008, 07:07 AM
  5. Bush declines to say whether he would remove
    By MR_GRUMPY in forum Politics Only
    Last Post: 10-21-2005, 10:09 AM
