Hydraulic brake line routing inside downtube
Results 1 to 6 of 6
    Reputation: Srode's Avatar
    Aug 2012
    I'm building a frame that has 2 spots for internal routing of cables in the downtube, and one external. I'm building this with Di2 so only one will be used for shifting, and leaves one open for alternate use. It's going to have hydraulic discs, so am thinking about routing it inside the downtube and out just under the bottom bracket enlarging one of the holes in the BB plastic cable guide to accommodate it and follow the chain stay. Are there any concerns or watch outs I should be aware of doing this? If it matters, it's R785 shifters on a Niner RLT9 frame. When Niner builds the bike spec'd like this they run the hydraulic line down the outside not the inside. When I called and asked about it they said the hose won't fit out the BB guide which I would modify to fit. Thoughts?
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    BH G7 Disc
    Trek Crockett
    Reputation: ghettocop's Avatar
    Apr 2014
    There is obviously a huge diameter increase when comparing a hydraulic hose to a shift cable, but if you are able to modify the BB cable guide without destroying it, there shouldn't be any problems. Is the entry port at the top of the down tube large enough to fit the hose?
    Aug 2012
    Surprisingly to me anyway, the OD size of the hose is exactly the same as a regular brake cable housing at 5mm so it fits in the entry port at the top and the bottom only needs to go from a 4mm shift cable bore to the 5mm size.
    Gravel Rocks
    Trek Domane
    BH G7 Disc
    Trek Crockett
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Drill it out. You can always replace it with a new one.
    If it were me, I'd just take it off. You don't need it. It'd probably give you a smoother bend.
    'brifter' is a lame word.
    ^This^ No need for it, and if it's gone you'll have be able to run the hydro line directly out of the frame and not bend it.
    I work for some bike racers
    and a bunch of skateboards
    Aug 2012
    Thanks everyone, so I will definitely run it inside. I was thinking that plastic piece drilled will keep the bottom from filling with debris / mud riding it on gravel roads or trails. I can smooth the bend just playing with a dremel and the plastic to make a curve for it to follow.
    Gravel Rocks
    Trek Domane
    BH G7 Disc
    Trek Crockett
  1. Hydraulic hose routing
    By tlg in forum Components, Wrenching
    Last Post: 07-30-2015, 04:15 AM
  2. Part for hydraulic brake
    By rumpypumpy in forum Components, Wrenching
    Last Post: 08-30-2014, 10:22 AM
  3. Hydraulic brake lines
    By Cinelli 82220 in forum Components, Wrenching
    Last Post: 02-18-2012, 06:44 PM
  4. Hydraulic brake conversion
    By zoikz in forum Components, Wrenching
    Last Post: 02-05-2012, 09:43 AM
  5. Hydraulic TT brake rim not disk
    By QuattroCreep in forum Components, Wrenching
    Last Post: 01-20-2012, 01:03 PM
