Hydraulic Braking issue
Results 1 to 13 of 13
    Reputation: Cni2i's Avatar
    Jun 2010
    Hey everyone.
    I recently had all my components/ drivetrain professionally (lbs) swapped from one frame set to another. Both are OPEN Up Frame sets. Brake rotors and pads unchanged. Pads are approximately 3 months old. No wet riding during this period.
    Drivetrain is the 2018 Ultegra Di2 Hydraulics 1x with XTR rear derailleur. Before the swap, braking worked flawlessly. After the swap, the rear brake just doesn’t engage properly. That is, it’s so unresponsive. The lever has to be fully depressed to get the brake to engage. And even then, braking is very “weak”. Front brake absolutely no issue.
    Shop did a quick rebleed, stating likely due to air bubble in the system. This seemed to solve the issue for 3/4 of one ride. . Then same issue arose. Brought her back to shop. They did a more “complete “ (?) rebleed. This time, rear brake worked fine for two rides. On the third, same thing! Brake just wouldn’t engage properly.
    Planning on bringing her back. But would love to hear about other probable causes besides air bubbles. And if due to air bubbles, do I have them rebleed again? Just trying to figure out why this keeps happening.
    EyeGuy
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I'm thinking somehow in this process, the rear brake lever was depressed while the wheel was out. Usually this results in brake rub, but I am thinking what is possibly going on here is that one pad is making contact with the disc before the other, thereby giving you a loss of braking power.
    You may want to have your shop reset the calipers. They will have to spread them. It's a fairly easy process.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    'brifter' is f'ing stupid
    Quote Originally Posted by Cni2i View Post
    Hey everyone.
    The shop handed the bike off to you and the rear brake didn't work properly?!? The frame has internal routing so they'd have to separate the hose at one end to get it through the frame. This would normally necessitate a bleed. There is only ONE way to bleed a brake, that is putting fluid in at one end and having fluid/air come out at the other end. There is no 'partial' or 'quick' bleed. If the process is done correctly there should be no problems. Sounds to me like your shop is not following the correct procedure.
    What? When you bleed a brake both pistons are pressed back into the caliper and a bleed block is inserted. The pads are removed. You don't 'reset' calipers, you push pistons back.
    #promechaniclife
    Banned Sock Puppet
    May 2014
    OK, I used the wrong terminology. When I said reset, I meant pushed back.
    On the bleed issue, I stand corrected - provided the shop did it correctly the way you said.
    "With
    -- DCGriz, RBR.
    Feb 2013
    This is 100% correct. I only a novice not a professional bike mechanic. With a minor cost for tools you can do this yourself. Bought hydraulic brakes for my CX bike. Hose was to short so I had to replace. Followed Shimano’s detailed instructions and had no problem. Installed the funnel at brake lever and injected fluid into bleed screw and pushed air and fluid into funnel. Then proceeded to pump brake and crack bleeder. Worked perfectly. Also lots of YouTube videos on this.
    Jun 2010
    Thanks for the replies guys.
    Cxwrench: when they handed my bike back, all was well for part of the first ride. About 1/2 way through the ride, the rear brake issue reappeared. I brought her back in and the mechanic rebled the brake system. Tbh, not sure exactly what/how he did it. I just took his word for it, that he would rebleed the system to flush out all air bubbles. The second time around, the rear brake worked “normal” for two rides. On the third ride, the same issue reappeared?!?! Just not sure why it would work fine for two full rides then stopped working properly all of a sudden.
    I was planning on dropping the bike in today after my morning ride. Okay, so the first 1/3 of the ride, rear brake was faulty as expected. But then, it started to spontaneously engage better again?! Maybe still not quite as good as the front brake, but about 85% as good. Again, I’m definitely not a wrench, so not sure what’s going on. Could repeated pressing of the brake lever move the air bubble out???
    Apologies for the confusion, but I’m confused myself. Just wanted to get feedbacks from you guys so I can relay sensible info to the shop mechanic.
    Ty.
    EyeGuy
    Jan 2014
    Ty.
    I’m just an amateur mechanic too; I’ve set up and bled hydraulic brakes half a dozen time or so. And everything cxwrench said should be the final word on how you bleed brakes.
    But I agree with you, OP: the fact that the firmness of the brake lever seems to be changing during and between rides – that doesn’t make any sense.
    In my experience, if the brakes aren’t bled properly (if there are air bubbles in the system) then the brake lever is mushy. If the brakes ARE bled properly, the lever is firm and the brakes are solid.
    But the hydraulic system is supposed to be a closed system: you should not be able to “flush the air out” while riding the bike. I genuinely don’t understand how the brakes are going from good to bad and back again. And this makes me wonder if there is something else or something more wrong than the hydraulic bleed – like something going on in the brake caliper or in the master cylinder in the hood. Maybe a piston is sticking and then unsticking...
    I dunno, but the theory that the brakes weren’t bled properly is not enough to explain the phenomena you are reporting to us here. It may be that the brakes weren’t bled properly, but it’s not only that...
    Oct 2017
    This is a timely youtube channel update from Park Tools showing in detail how your hydryaulic brake pistons work.
    Jun 2010
    Quote Originally Posted by fronesis View Post
    Thank you for that explanation. Yeah, each time he bled the brake system, braking was firm and engaged as expected. But then like I said, it goes bad again. Happened twice as mentioned above. But when it became spontaneously firmer again during the ride...I was like “phew”...but had me scratching my head wondering what’s going on. I’ll mention some of the things you mentioned to the mechanic this week.
    EyeGuy
    When you pick the bike up put it up on the rear wheel, vertical. Pull the levers a bunch and see if they stay firm. A LOT of times this will let air in the system to work it's way to the master/lever and the brake will get soft. I always do this after a bleed just to make sure.
    #promechaniclife
    Jun 2010
    Thank you. I will.
    EyeGuy
    Jan 2014
    That makes a lot of sense: it explains how a system that wasn't bled properly might not immediately reveal itself as problem. But once the air bubbles make their way up into the master cylinder, you get a mushy lever. (My bike rack at home holds my bike vertical this way, so a crappy bleed shows itself immediately.)
    Oct 2005
    If they are doing the bleeding procedure correctly there may be a leak somewhere in the system that's allowing more air to eventually find its way inside. Perhaps they buggered up something when reattaching the hose after routing it through your frame? Check to see if any brake fluid is visible at hose connections, bleed/fill ports, etc.
  1. Shimano Hydraulic ST-RS685 or Sram Hydraulic
    By Kuna in forum Cyclocross
    Last Post: 07-24-2015, 05:43 AM
  2. 05' Team Issue vs Team Issue Euro?
    By david462 in forum Fuji
    Last Post: 02-02-2010, 06:11 PM
  3. Hydraulic gears
    By Malcog in forum Components, Wrenching
    Last Post: 09-13-2006, 11:35 PM
  4. high speed braking issue
    By Travis in forum General Cycling Discussion
    Last Post: 05-12-2006, 08:14 AM
  5. Is there such a beast? - hydraulic disc brakes for roadbikes?
    By fisherman in forum Components, Wrenching
    Last Post: 02-17-2006, 01:06 PM
