Hydraulic Disc Brake Caliper Spreading Tool
Results 1 to 12 of 12
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Which is the best one for Shimano hydraulic disc brakes? I have a slight rear brake rub and need to reset the brakes.
    Thank you all in advance!
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Plastic tire lever always works for me.
    Russian Troll Farmer
    Sep 2016
    A small screwdriver
    "L'enfer, c'est les autres"
    Banned Sock Puppet
    May 2014
    Seriously, this would be skinny enough to get in there?
    A small screwdriver
    Hmmm, who would've thought!
    "With
    -- DCGriz, RBR.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Remove the wheel and the pads, a blue Park Tool lever is plenty small enough. Just don't pull the brake lever with the wheel and pads out.
    tlg
    tlg is online now
    May 2011
    Try it.
    I can fit the tip of my Pedro levers between the pads and spread them.
    tlg
    tlg is online now
    May 2011
    With the pads removed, you can fit all sorts of things inside to safely retract them.
    'brifter' is a lame word.
    A small screwdriver
    Not unless you're planning on replacing the pads.
    I work for some bike racers
    and a bunch of skateboards
    Banned Sock Puppet
    May 2014
    Well then, I guess I won't be doing that.
    Nothing like the right tools for the job!
    "With
    -- DCGriz, RBR.
    Dec 2012
    Visit your mother and ask politely for a wooden spring clothespin. Take it apart and you have 2 spreaders. The taper allows them to be used as sliding shims that won't scratch any surface. Honestly anything with a smooth flat surface will work. You are overthinking the problem.
    Sep 2011
    Banned Sock Puppet
    May 2014
    Whew! Thanks for the eye candy.
    "With
    -- DCGriz, RBR.
  1. Replies: 27
    Last Post: 04-23-2017, 04:57 PM
  2. Disc Front Brake / Rim Caliper Rear Brake Experiment
    By mrwirey in forum General Cycling Discussion
    Last Post: 02-20-2016, 04:08 AM
  3. disc brake to caliper brake conversion?
    By cyclisme! in forum Components, Wrenching
    Last Post: 09-24-2015, 10:01 AM
  4. Shimano Hydraulic ST-RS685 or Sram Hydraulic
    By Kuna in forum Cyclocross
    Last Post: 07-24-2015, 05:43 AM
  5. Replies: 1
    Last Post: 09-18-2014, 04:34 PM
