Improve gearing
Results 1 to 11 of 11
Thread: Improve gearing
    Aug 2020
    Improve gearing
    I bought a Specialized Sirrus X 3.0 this year during COVID and have been enjoying it but have made a few upgrades to make it a bit more comfortable. I was thinking of improving the gearing. Its currently a 1x9 which is ok but I don't really use the granny gear , curious of any recommendations to the below setup. I will eventually move to a road bike but want to enjoy this one as long as possible but just try to get a little faster with the right gearing. I may also change the crank, the stock one seems to losen up once and a while and creeks on the left side. Thanks in advance
    SHIFT LEVERSmicroSHIFT Advent, 9-speed
    REAR DERAILLEURmicroSHIFT Advent, 1x9 w/ clutch
    CASSETTEmicroSHIFT Advent, 9-speed, 11-42t
    CHAINRINGS40T, Narrow-wide Steel
    BOTTOM BRACKETThreaded BSA 68mm
    CHAINKMC X9, 9-speed w/ Missing Link
    Sent from my SM-G970U using Tapatalk
    'brifter' is f'ing stupid
    You use the 42/11 a lot? How fast are you riding?
    #promechaniclife
    Aug 2020
    I attached my averages from my last long ride. I feel like I'm pedaling at a pretty good pace and road bikes just cruise by effortlessly LOL I dont plan on trying to beat a road bike, just get better gearing than stock. ill upgrade to a road bike once I out grow this one. Thanks
    I don't know why you think changing your 'gearing' will make you faster. Not gonna happen.
    ETA: Your avg cadence is kinda low. 72 avg means you're spending a considerable amount of time w/ a significantly lower cadence.
    #promechaniclife
    Oct 2013
    If you get in the '11' and you pedal 80rpm, your do'in 23mph. Those roadie's will not just ride by you. At 60 rpm, your doing 17.5mph.
    Your problem isn't the gearing it's your legs.
    Most pedal somewhere in that range. If you put a bigger chainring on, you can pick up some top speed, if you can put out more power. But if you just getting started, your better off learning to spin more, it's better.
    I'm revolting against my 3rd grade english teacher, your on her side I see. HA!
    BANNED
    If you get in the '11' and you pedal 80rpm, you're do'in 23mph. Those roadie's will not just ride by you. At 60 rpm, you're doing 17.5mph.
    Most pedal somewhere in that range. If you put a bigger chainring on, you can pick up some top speed, if you can put out more power. But if you're just getting started, you're better off learning to spin more, it's better.
    Seriously...you don't know how this works?
    #promechaniclife
    Feb 2002
    Un-trainable.
    Maybe you just assumed said poster made mistake without actually reading? Which usually isn't a bad bet but I don't see any problem with what you put in bold.
    Sep 2011
    Those are the corrections. The original "quoted" post is above for reference.
    Quote Originally Posted by 202cycle View Post
    ah, thanks for clearing that up for me.
    Oct 2013
    I'm going with 'difficult to train'.
    BANNED
  1. Improve your erection quality!
    By HAL9000 in forum SiteFeedback/Issues
    Last Post: 10-11-2004, 11:52 AM
  2. Improve your erection quality!
    By HAL9000 in forum The Lounge
  3. Help - I need tips to improve sprints
    By bimini in forum Racing, Training, Nutrition, Triathlons
    Last Post: 05-07-2004, 11:53 AM
  4. What's the best way to improve average speed?
    By the sky above, tar below in forum General Cycling Discussion
    Last Post: 03-31-2004, 05:38 PM
  5. Cheap way to "improve" your bike
    By stinkfoot247 in forum General Cycling Discussion
    Last Post: 03-04-2004, 03:13 PM
