Install HED Jet 5 on a Felt AR5
Results 1 to 7 of 7
    Apr 2018
    Hi everyone
    I met yesterday a guy who sells a pair of HED Jet 5 clincher so I mounted the rear wheel on my bike (Felt AR5) but the brake pads were so close to the wheel that I could not roll with it.
    Is there a way to adjust the break width so that a larger wheel would fit ? for those who don't know the break on this bike is hidden behind the bottom bracket and there is a quick release also near the handlebar.
    Thanks !
    'brifter' is f'ing stupid
    ALL brakes are adjustable. Post a photo and I'll explain.
    #promechaniclife
    Apr 2018
    Here are some pics (not with the new wheels though).
    If you can't figure this out I'd recommend taking your bike to a shop and having a qualified mechanic make the adjustment. I'm really not trying to sound like a dick but this is both easy and obvious. Maybe you can have the mechanic show you how it works.
    #promechaniclife
    Feb 2002
    Quote Originally Posted by StarySky View Post
    Hi everyone
    Thanks !
    What CX said. Study the brake and if you can't see how to loosen the cable clamp and let the brake open up a bit, then you need to take it to a shop.
    Apr 2018
    I know how to do it (and that I did) by adjusting the tension of the cable. My question was if there is an easier way with a barrel adjuster for instance but I don't see any on my bike.
    Well, there ya go. There is a centering screw on the NDS (left) of the brake, in the little 'V' made by the 2 arms, under the Shimano logo. You said nothing in your OP about knowing how to loosen the cable by undoing the anchor bolt and letting the cable through. You should probably be a little more clear the next time.
    #promechaniclife
  1. Difference between HED Jet 5 and Jet 5 Express
    By jayteepee in forum Wheels and Tires
    Last Post: 01-07-2017, 05:13 PM
  2. Help choose between HED H3 tri-spoke and HED JET 90
    By stussy1035 in forum Wheels and Tires
    Last Post: 03-06-2016, 12:44 PM
  3. hed wheels - Jet 5, jet 4
    By turbodogs02 in forum Wheels and Tires
    Last Post: 05-11-2012, 06:24 AM
  4. Replies: 2
    Last Post: 02-14-2012, 06:07 AM
  5. Cosmic Carbone SL Clincher vs. HED Alps or HED Jet 50
    By clozner in forum Wheels and Tires
    Last Post: 04-13-2009, 12:05 PM
