internal battery charging
Results 1 to 4 of 4
    Aug 2011
    For those running the BTR-2 seatpost battery, can we plug into the USB-electric adapter used to charge iPhones? Shimano instructions say an adapter must allow at least a 1.0A current flow, but I don't know specs on the Apple piece. Or any other wall socket adapter anyone's using? I have the BCR-2 charger.
    Reputation: looigi's Avatar
    Nov 2010
    Output spex of the Apple charger are printed right on it between the wall prongs. Not easy to see though. The ones I have are 1A.
    AFAIK, the output spex of all wall charges are printed on them somewhere: AC, DC, nominal voltage and max current. What's often not indicated is whether they're regulated or not. All USB chargers are regulated at a nominal 5V.
    ... 'cuz that's how I roll.
    Aug 2011
    Thanks for the reply---you're right, it is hard to read but looks like it meets the requirement. Easier than using a laptop all the time, at least in my house.
    Jan 2012
    Yes, at least the iPhone AC adapter I have meets the specs. I had to use a magnifying glass to read the output specs from the adapter, but 5V - 1A meets the charging requirements of the battery
  1. internal battery charging
    By gaspasser in forum Shimano
    Last Post: 01-14-2014, 05:30 AM
  2. Replies: 2
    Last Post: 11-19-2013, 05:43 PM
  3. Charging systems. Solar/ mechanical/ spare battery etc...
    By medialab in forum General Cycling Discussion
    Last Post: 11-27-2011, 02:10 PM
  4. battery charging for NiteRider headlights?
    By wgp in forum Components, Wrenching
    Last Post: 09-18-2008, 05:38 AM
  5. charging a car battery....sorta...but bigger
    By jahona in forum The Lounge
    Last Post: 08-29-2007, 06:11 AM
