Internal routing
Results 1 to 23 of 23
    May 2011
    Internal routing
    Wow! Just replaced my first set of cables on a bike with internal cable routing. Who the HELL ever thought THAT was a good idea??! Maybe invented by a mechanic who got paid by the hour?! Nothing like turning an 1.5 hour job into one taking 4 hours! It'd better be saving me several *pounds* of drag to justify that much time and hassle.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Not that hard IME. Last week I installed 2 sets of these shifters in less than 1.5 hours.
    Even my first set I ever installed only took 45 minutes.
    This is coming from a mechanic who gets paid by the hour. Just have to follow the instructions. They are pretty well written out.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Reputation: rbart4506's Avatar
    Aug 2004
    First step....Figure out if there are cable guides, or if the housing goes straight through....
    You need to make sure there is a path for the new cable to follow...
    If not and you are dealing with an open cavity then thread and a shop vac are your friend
    Been there, done that...
    Reputation: boneman's Avatar
    Nov 2001
    good one
    creative solution...i like it
    Quote Originally Posted by rbart4506 View Post
    i've got limited minutes left in life, don't waste my time
    Reputation: stevesbike's Avatar
    Jun 2002
    better idea is to use the old cables as guides - cut them before hole opening to main downtube internal section, tape new cable ending to old cable, pull the cable through gently.
    Dec 2010
    ^ This- replacing brake cable in the top tube seems faster than with external cables.
    Mar 2003
    I'm especially fond of the new paths rain/moisture/sweat have for getting inside your expensive frame that internal cable routing provides.
    Reputation: Oracle7775's Avatar
    Sep 2009
    I straighten out a wire coathanger so that it's long enough to go through the frame, tape the cable to one end, and then just stick the coathanger through and pull it out the other side.
    Don't take anything I say seriously.
    'brifter' is a lame word.
    Quote Originally Posted by OldChipper View Post
    1.5hr to install cables on ONE bike? really...that long?
    I work for some bike racers
    and a bunch of skateboards
    May 2011
    Nope, no internal cable guides and yep, did a lot of fishing. Suggestions work OK for down tube but still a fair amount of fishing to get the cable through the chain stay plus through the fiddly short tubes attached to the fittings plus taking the fittings on/off is a pain- cable stops are way better IMHO.
    If there are "instructions" out there for how to do it better, I'd be forever indebted for a link to or post of them.
    I was referring to the entire job I.e. Un-tape, pull cables, thread cables, adjust cables, re-tape with my 1.5 hr estimate. Could probably do it faster if I had to. I've built MANY "old-school" bikes from the frame up and am an engineer by profession so I know my way around a bike and a wrench.
    Reputation: bwhite_4's Avatar
    Aug 2006
    Bikes with internal cable routing should have cable guides, plain and simple. For a manufacturer or builder to leave them out shows some serious flaws in their design and thought process.
    Mehpic
    Reputation: 2cflyr's Avatar
    Apr 2002
    Quote Originally Posted by bwhite_4 View Post
    some brands do, others dont.
    felt does, which is definitely nice.
    i recently re-housed an older trek or specialized tt/tri bike that didn't. we managed to get the shifter housings twisted inside of the downtube. not fun. resorted to vacuum/string.
    catzilla: I wish we were all a little more invincible.
    The NEGU Foundation: Caring for Courageous Kids http://www.thenegufoundation.org/
    May 2011
    Yep, it's a Specialized Roubaix. I'd be *really* pissed if it was a $5k -$7k frame and it didn't have guides. Guess that's what I get for "only" spending about $4 grand on a bike!
    Mehpic
    Apr 2002
    some of the mid/upper colnagos are going all internal as they're coming with a Di2 spec. as someone who works at a colnago shop, i'm a little worried to see what their plan of attack is....that and I want a CX-1, which is definitely internal.
    oh and oldchipper- did you have to deal with the 4mm housing issue on the specialized? the tri bike we worked on required 4mm housing which sucked, especially because the owner wanted red housing, which he gave us...but it was 5mm.
    Anti-Hero
    Reputation: Andrea138's Avatar
    Mar 2008
    It's not that bad... all you need are some picks, a headlamp, and a lot of patience.
    No turkey unless it's a club sandwich
    Brickhouse Blog
    Quote Originally Posted by 2cflyr View Post
    5mm shift housing? that's still around? just make him buy some that is the 'industry standard' and he's all set.
    May 2011
    Nope, I was installing the Yokozuna Reaction cables/housing and they worked. The brake housing was a bit snug, but once I filed down the ends a bit they slipped in OK. Shift housing was perfect.
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    In my experience, there's good internal, bad, and really bad. I worked on a Specialized recently that was great. And I've warrantied 2009 Cervelos for hideous cable routing problems causing poor shifting. The current Cervelos are much better, but are often tedious.
    Reputation: rs3o's Avatar
    Wow. Sounds like lots of folks are doing it the hard way. For frames without internal cable tubing, get a few lengths of housing liner (http://www.jensonusa.com/store/produ...ing+Liner.aspx). Before removing old cables from frame, slide a length of housing liner onto cable from the derailleur end or brake end. Feed liner all the way through the section of frame, then remove that section of old cable leaving the liner in place. Repeat as necessary such that all the sections of internally routed cables have been replaced by housing liner. Next, replace cables and housing, sliding the cables through the housing liner, then removing each section of housing liner once the cables are all the way through that section. Save the housing liner for the next time you replace cables. Easy.
    May 2011
    Quote Originally Posted by rs3o View Post
    Now THAT 'S what I'm talking about! Great tip! Can't believe I didn't think of that. Thanks!
    Apr 2011
    That'll fix everything!
    Oh, wait. I'm building new bikes that don't already have cables in them.
    Personally, my favorite idea is the vacuum one, but they all will get you out of a jam. However, really well designed internal cabling doesn't require any technique - you stick the cables in and they come out of the right holes.
    Reputation: thebikingcello's Avatar
    Feb 2011
    and that is why I will always have bikes with external cable routing. And I will go to hell and back to get a TT bike with external routing... If I ever wanted a TT bike
    Bikes:
    Felt F95 2011: my main road ride
    Jamis Dragon 29 Sport 2011: my main MTB(Steel is Real)
    Raleigh Record 1976: Single speed in the making
    Possible Fuji cross frame I might get... and paint...
    May 2011
    Quote Originally Posted by kontact View Post
    however, really well designed internal cabling doesn't require any technique - you stick the cables in and they come out of the right holes.
    +1(000)
  1. internal cable routing?
    By stevesbike in forum Components, Wrenching
    Last Post: 04-08-2013, 02:04 PM
  2. internal cable routing...
    By jyeager in forum Components, Wrenching
    Last Post: 05-22-2009, 02:43 PM
  3. Internal cable routing?
    By krisdrum in forum Cyclocross
    Last Post: 03-08-2009, 07:49 AM
  4. Internal Cable Routing Q
    By fezzy in forum Look
    Last Post: 08-04-2007, 12:37 PM
  5. internal cable routing
    By kenyonCycleist in forum Components, Wrenching
    Last Post: 12-29-2004, 09:19 PM
