Jagwire cable housing
Results 1 to 4 of 4
    Apr 2002
    I am replacing cables and housings and was going to buy Shimano housing as it worked fine before.
    But Performance and another shop recommended Jagwire as it is supposedly better quality than Shimano so I bought brake and shifter housings.
    I noticed however, there seems to be more friction between the cable and the hole going through the housing - it seems the hole in the JW is smaller in diameter. And it seems more prep is required to open the hole up on the ends also - (I have the Park cable/housing cutting tool) but.
    Anyone used both Shimano and Jagwire and housings and noticed any differences, especially friction wise?
    Thanks in advance.
    Jan 2009
    I don't know who supplies the housing Shimano sells under their own label in the USA, but JagWire supplies most of the cables and housings used as original equipment on Shimano equipted bikes.
    In my experience, I've never noticed a quality difference between the better grades of Jag and Shimano cables or housings.
    fb
    www.chain-l.com
    Solving any problem requires understanding the underlying cause
    Apr 2002
    Maybe the grade of housing I got is the issue. I wasn't aware they made different grades - the one I bought is one dollar per foot which is pretty cheap.
    In any case, I'll use it because I bought and hope the tension I feel is imaginary.
    Thanks!
    Militant commuter
    Reputation: SilverStar's Avatar
    Jan 2008
    Jagwire is good stuff...just run a sharp awl or sharpened spoke into the hole to flare it out after cutting it and you'll be fine.
    "Luminous beings are we...not this crude matter!"
  1. Replacing cables & housing - Jagwire Racer kit
    By thatdrewguy in forum Components, Wrenching
    Last Post: 03-07-2012, 01:15 PM
  2. Jagwire Shifter Cable Labeled Wrong
    By weltyed in forum Components, Wrenching
    Last Post: 03-25-2009, 08:04 AM
  3. Jagwire Road Racer cable set
    By Loch in forum Components, Wrenching
    Last Post: 02-15-2009, 04:41 PM
  4. Jagwire rocket cable adjusters.
    By cyclust in forum Components, Wrenching
    Last Post: 10-04-2008, 09:59 AM
  5. Internal Brake Housing...Cable Housing....
    By spepic in forum Components, Wrenching
    Last Post: 07-14-2008, 05:40 PM
