Ksyrium freehub lubricant
Results 1 to 2 of 2
    Reputation: martroy's Avatar
    Mar 2004
    I've lubed the inside of my Ksyrium freehub but since my lbs didn't have Mavic's lightweight mineral oil. They suggested that I use Finish Line cross country chain lube instead which I've used but it seems a bit thin and is leaking a bit around the rubber seal at the bottom of the freehub body. Do you have anything else to suggest ? I had to re-lube it after a week because of a squeaking noise...
    Thanks
    Martin
    Montreal, Quebec
    New Member
    Reputation: divve's Avatar
    May 2002
    I use 80W90 gear oil which works flawlessly. Only apply a medium coat of oil inside the hub - about 20 drops is sufficient. You should be able to find the stuff at a car accessory shop. It's real cheap too compared to so called bike specific lubes.
  1. Mavic Ksyrium Equipe vs. Mavic Ksyrium Elite
    By gobuffs in forum Components, Wrenching
    Last Post: 05-08-2012, 09:50 AM
  2. shimano r540 vs. ksyrium elite
    By ZG82 in forum Components, Wrenching
    Last Post: 06-24-2004, 01:40 PM
  3. Ksyrium freehub removal
    By munga22 in forum Components, Wrenching
    Last Post: 06-14-2004, 10:25 AM
  4. Mavic Ksyrium ED10 freehub body
    By Eric_H in forum Components, Wrenching
    Last Post: 02-27-2004, 01:57 PM
  5. Mavic freehub (campy version)
    By boat in forum Components, Wrenching
    Last Post: 02-15-2004, 04:59 PM
