Lateral movement in my Campy UT.....Help
Results 1 to 6 of 6
    Feb 2007
    I have been riding 1000km. on my Pinarello Prince with Record UT crankset. Now there is clicking sounds from the crankset and I have detected a little lateral movement when I press on the left crankarm.
    I have cleaned and regreased it and tighten the bolt at the right torque (about 43nm)
    What is wrong?
    Looking for my Amish Love
    Reputation: capt_phun's Avatar
    Jun 2004
    Campy recommends you can torque that bolt up to 60Nm. That is what I needed to due to get the wave washer to properly engage the bearings & prevent lateral movement.
    May 2005
    Is the retention clip on the drive side cup?
    Jul 2006
    My two guesses have already been covered above. Hope that fixes it for you.
    May 2004
    Quote Originally Posted by capt_phun
    60 Nm? I just installed mine (Chorus level) and the manual that came with the crankset indicated that the proper torque was 42 Nm. I didn't see 60 Nm mentioned anywhere.
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by kfurrow
    Campagnolo published a correction in June '07. There were reports of fixing bolts coming loose at 42 Nm, so they upped the maximum torque to 60 Nm. Someone from Campy wrote somewhere that 70 Nm is fine too, if needed
    http://www.campagnolo.com/repository...orque_0607.pdf
