Results 1 to 9 of 9
    Aug 2012
    Look Keo adjustment (side)
    I have a knockoff brand (cheap) Look Keo pedals. I noticed one side had a little more play than the other, w/o coming off. I tightened the main tension adjustment and that seemed to cure it and even them out, but I notice another small allen adjustment on the side, what is that for?
    'brifter' is a lame word.
    No idea. There is only one adjustment on Look pedals. Are you talking about the pivot bushing for the tail piece?
    I work for some bike racers
    and a bunch of skateboards
    Dec 2006
    Please post a photo. Sounds like a rotational adjustment screw.
    Reputation: velodog's Avatar
    Sep 2007
    Probably this
    Too old to ride plastic
    Aug 2012
    I noticed one of my cleats "loose" compared to the other one, I wasn't popping out but I had what seemed like float I didn't need. Note: I have only used black cleats so I don't what float feels like. I see when I turn this with the allen that there is another allen hole on the other side that turns too. Maybe it is just to take cleat apart. Never the less, I tightened the adjustment on the top and that seemed to take care of the loose feeling cleat.
    Could you take any worse photos?
    That's the pivot for the tail piece of the pedal. When you clip in that piece moves backwards and then clips over the back of the cleat. Should be very obvious from just looking at the pedal. It is NOT an adjustment of any kind.
    Dec 2006
    While I wouldn't be so blunt, I have to agree. I can't even tell the photos are of pedals, or cleats.
    Sep 2007
    Quote Originally Posted by Peter P. View Post
    Yeah, but the plastic chair and what looks like a broom leaning against the wall are as clear as a bell.
    Aug 2012
    probably not. but i figured you guys with +10,000 posts are so smart you could figure this out with only the slightest glimpse. It was cold in my garage last night, probably should redo in sunlight.
    I could go with that. When I study the pedal I see there is another one on the other side. And when I turn one, the one on the other side turns, so I guess if you lock on still, and reverse the other one, something comes apart.
  1. LOOK Keo 2 Max. Is q-factor same as Keo classic?
    By 9W9W in forum Components, Wrenching
    Last Post: 06-09-2014, 01:33 PM
  2. Look Keo 2 Max or Keo Sprint?
    By maximum7 in forum General Cycling Discussion
    Last Post: 12-16-2011, 04:10 PM
  3. Look Keo Blade vs. Keo 2 Max
    By SolidSnake03 in forum Components, Wrenching
    Last Post: 09-10-2011, 12:19 PM
  4. Look Keo Carbon versus Keo Sprint
    By bigdeal in forum Components, Wrenching
    Last Post: 06-07-2006, 11:17 AM
  5. Look Keo Classic vs Keo Sprint and cleat differences
    By Lt. in forum Components, Wrenching
    Last Post: 11-16-2005, 09:45 AM
