Looking For Flat bar Shifter for ULTEGRA 10 speed Crank set
Results 1 to 5 of 5
    Apr 2018
    HI... Using aN uLTEGRA 10 x 2 speed gruop et but want to move from drop Handle bar to Flat handle bar.. Can anyone suggest Shifters for Flat Handle bar for ULTEGRA 10 Speed Crankset... ? Any Experience if somebody has done the change?
    Oct 2013
    I think your going to need new shifters & derailuer's. Do you have mech or disk, hydro or cable brakes?
    BANNED
    'brifter' is a lame word.
    If you have cable operated brakes you'd be looking for Tiagra 4600 shifters. NOT Tiagra 4700 unless you buy the derailleurs as well.
    I work for some bike racers
    and a bunch of skateboards
    Apr 2018
    Yes.. Using cable brakes.. Will look for Tiagra 4600..Tks
    Reputation: JCavilia's Avatar
    Sep 2005
    Quote Originally Posted by Moonlight View Post
    And when you're shopping, make sure you're getting the FLAT BAR 4600 shifter. There's a drop-bar brake/shift lever with the same number. And of course you'll need brake levers, too. I think there are several that are compatible.
    "None of us knows for sure what's out there; that's why we keep looking. Keep your faith; travel hopefully. The universe will surprise you, constantly." The 13th Doctor.
  1. Flat Bar bike set up Reach - Bar Height question
    By Har in forum General Cycling Discussion
    Last Post: 06-13-2016, 08:49 PM
  2. Ultegra 9sd FD & RD, needing flat bar shifter/levers
    By db-xlt in forum Components, Wrenching
    Last Post: 12-12-2013, 10:58 PM
  3. Shimano 10 speed crank set with 9 speed set up
    By shakyfish in forum Components, Wrenching
    Last Post: 08-01-2012, 06:37 PM
  4. Replies: 8
    Last Post: 10-12-2007, 05:28 AM
  5. Flat after flat after flat after...
    By PaulCL in forum Wheels and Tires
    Last Post: 10-04-2005, 08:56 AM
