Master Link Stuck...very stuck
Results 1 to 15 of 15
    Apr 2012
    Ive been trying to get the master link off my chain for the last hour. So far I broke a pair of needle nose pliers, a hexkey, and a screwdriver. Its a two piece type with one pin on each side. Something like this
    Any ideas? Im about to throw the whole bike out the window....
    Apr 2004
    just use a chain link tool and break both pins. Then go buy a replacement.
    Sep 2008
    or get a master link pliers I have one and use it all the time it's very quick at opening the master link.
    Park Tool Co. MLP-1 : Master Link Pliers : Chain
    Remember it's mind over matter
    if you don't mind it doesn't matter
    Ride more drive less
    Apr 2012
    Finally got it. Used some wire and wrapped it around the link and pulled like crazy. My god....it would have been faster to take the whole chain apart and put it all back together again. Im going to have to pick up those master link pliers.....
    Reputation: Andy M-S's Avatar
    Quote Originally Posted by whatthefunk View Post
    Use two sets of needle-nose pliers. The Trick is to squeeze the plates together with one set, while using another set (with really fine jaws, so you can fit them between the plates) to apply pressure on the pins/rollers on either end. The link should squeeze together, then you twist the second set to free the plates from the pins. If the link is really dirty, that can make it difficult as well, so soak it down with WD40. And remember to de-tension the chain before you try to remove the link.
    This wheel's on fire/rollin' down the road
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    The problem with pliars is they don't squeeze parallel so they slip off. Try 2 screwdrivers and squeeze them with 2 pliars top and bottom. Then you can squeeze the link parallel.
    I made myself a set of link pliars from a pair of dog toenail clippers. Took a dremmel and ground it down to fit between the links and a round groove so it doesn't slip off. Links pop right open.
    Moose > Clydesdale
    Aug 2012
    I've had this same issue with master links in the past. Do yourself a favor and get the tool linked below.
    Quote Originally Posted by ezdoesit View Post
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    Back when I worked at the LBS I learned a trick that works every time. Use a pair of channel lock pliers. Pinch the chain exposing the quick link. Pliers will be flat, parallel with the ground. The angle of the pliers nose allows you to put pressure on the proper sides of the quick link and leaves a small gap so the link can snap apart.
    Reputation: looigi's Avatar
    Nov 2010
    The SRAM 10 speed quick links can be difficult to get off. I have used the two driver or allen wrench method as illustrated in a previous post and also the channel lock method describe by ZenC. I then modified an old crimper into link pliers using a grinder. Finally, I got the Park link pliers. They all worked, but the last worked the best and is least likely to damage the link allowing it to be reused, which I do, for the life of the chain, removing and reinstalling it 8-10 times over the life of the chain for thorough cleaning or when packing the bike into a case for traveling. YMMV
    ... 'cuz that's how I roll.
    Jun 2007
    EZ et al - thanks for the tip on the Master Link Pliers. $14.49 on Amazon with free shipping if you are a Prime member (which I am addicted to).
    Amazon.com: Park Tool MLP-1 Master Link Pliers: Sports & Outdoors
    Burnum Upus Quadricepus
    Reputation: brucew's Avatar
    Jun 2006
    What size is the bike?
    Reputation: Tlaloc's Avatar
    May 2005
    Reusable?
    Some master links are not meant to be reusable. The Connex link is. You can easily undo the Connex link with your hands. I use Connex chains as well. I'm using an expensive one:
    2013 Wippermann Connex 10SX 6.05mm Stainless Chain - Competitive Cyclist
    that has stainless links and nickel plated outer links. It costs $80 but this summer I used it and Prolink chain lube and my chain is only showing 25% wear on my Park chain stretch tool after about 3,500 miles. I've used these chains for many years and always liked them.
    Cathedral City, CA
    Nov 2005
    2016 Ritchey BreakAway (carbon)
    Full Campagnolo drivetrain - Chorus 11sp (50, 34 & 12-29)
    Zonda wheels
    Lezyne Super GPS w/Cateye speed/cadence & HR sensors
    Ritchey fork, stem, headset, bars and seatpost
    Fizik Arione VSX saddle
    Cinelli bar tape
    BeBop Pedals
    Nov 2010
    By the standards of this group, I'm a below average mech. I have always hated the conex links because they were harder for me to break apart than to just use a chain tool. But I just finished breaking apart a worn chain that had a conex link using the tips. Just wanted to say thanks.
