Merlin Magia fork rake
Results 1 to 3 of 3
    Oct 2005
    I had bad crash on my Merlin Magia, but I think my body got the worst of it. That said, I知 seriously considering replacing the fork but am unsure what fork rake to look for. I値l take it to a shop to do the work and I知 assuming they will be able to determine what I need. However it never hurts to do a little homework beforehand.
    Any input from the forum?
    Dec 2006
    Usually, carbon forks will have a sticker in the steerer tube with serial number, rake, and possibly manufacturer codes. Pull your fork and check. Look for a two-digit number between 40 and 50.
    'brifter' is f'ing stupid
    Related to head tube angle big time. The slacker the head tube angle the more offset, steeper head tubes = less offset. Normal size frame you're probably looking @ 43-45mm. As Peter P. posted it will nearly always be marked on the steerer somewhere.
    #promechaniclife
  1. Replies: 20
    Last Post: 07-15-2011, 06:23 PM
  2. What happened to the Merlin Magia?
    By cheekybondi in forum Litespeed - Merlin
    Last Post: 10-08-2009, 07:01 PM
  3. Fork rake on fork swap - can I swap these forks?
    By fabsroman in forum Components, Wrenching
    Last Post: 11-24-2007, 09:56 AM
  4. Merlin Magia vs Extralight
    By andrewb in forum Litespeed - Merlin
    Last Post: 08-26-2005, 07:17 AM
  5. Merlin Magia vs Extralight
    By andrewb in forum Bikes, Frames and Forks
    Last Post: 04-07-2005, 07:34 AM
