Missing Cooling Fins
Results 1 to 12 of 12
    Jun 2005
    I'm installing r8070 disc brakes. The rear brakes came with pads and cooling fins installed, but the front brakes do not have the cooling fins. Is it safe to use them like this?
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    I use pads without fins. No problem.
    I don't ride my brakes and I don't live in mountains with miles long descents.
    But it's odd that your pads came without them.
    'brifter' is f'ing stupid
    You do know that Shimano makes a bunch of brake pads that don't come with fins, right?
    #promechaniclife
    Jun 2005
    So why did my rear brakes come with fins and my front ones didnít?
    The only 2 reasons I can think of are:
    You ordered them that way and didn't realize it.
    Or:
    The place you ordered from doesn't know the difference and/or screwed with them. I've never seen flat mount calipers w/ non-fin pads.
    There are 3 non-finned pads for the calipers you have...
    K02S Resin
    K03S Resin
    K04S Metal
    and 3 finned pads...
    L02A Resin
    L03A Resin
    L04C Metal
    If it were me I'd just use the current pads and then replace w/ finned resin pads. Don't overthink it.
    #promechaniclife
    Oct 2005
    Don't overthink it.
    Yeah. Brake pads worked fine for YEARS before the finned style arrived relatively recently.
    The pads on my cars have no fins and I've yet to have them fail on me.
    Actually it doesn't matter at this point as the OP needs to order different calipers because his frame isn't flat mount. I'll bet this time the front comes w/ fins and the rear doesn't. The fins aren't 'installed' either...they either come w/ them or they don't. You can't add fins to non-finned pads.
    #promechaniclife
    Jun 2005
    The brakes are for a flat mount frame, and the flame is flat mount as well I bought the group set from Merlin. There were a few small issues with it. One shifter had an olive already inside of it, but the other one didnít. The rear brake has pads with separate fins. The front brake has pads but no fans. I was concerned that the fins hold the pads in position. Merlin also told me that the system was supposed to come with the easy joint fittings, but it did not. They said that they checked their remaining stock and everything else has the joint system. Not impressed.
    Your frame is not flat mount, it's post mount. The fins are not separate, they're part of the backing plate. The backing plate holds the pad in position via the threaded pin or the cotter pin that goes through the caliper/pad backing plates/spring. Fins have nothing to do w/ holding the pads in nor locating them in place. Generally Shimano hydro levers will come w/ olives installed.
    The fun of ordering parts on the internet. Yay.
    #promechaniclife
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    Jun 2005
    Quote Originally Posted by TiCoyote View Post
    Yeah, it is. I confused this thread w/ the one with the guy that ordered flat mount brakes for his post mount frame. @bleckb or something like that. Carry on.
    #promechaniclife
  1. Vortex Generator Fins
    By kmunny19 in forum The Lounge
    Last Post: 02-24-2011, 08:12 PM
  2. Nice cooling fins
    By RandB in forum General Cycling Discussion
    Last Post: 09-07-2009, 07:15 AM
  3. Call me crazy, but the Fins will make the SB if....
    By DIRT BOY in forum The Lounge
    Last Post: 12-29-2008, 07:02 AM
  4. Cooling Vest?
    By wolfereeno in forum Pro Cycling - Tour de France
    Last Post: 06-29-2004, 11:11 AM
  5. What's the point of the fins on brakepads?
    By Dave Hickey in forum General Cycling Discussion
    Last Post: 05-05-2004, 10:20 AM
