need help with rear wheel noise
Results 1 to 5 of 5
    Jun 2003
    i have a ritchey WCS aero rear wheel with zero hub that seems to spin freely/smoothly without noise, but when i put it on the bike and ride, it has a rub/squeak noise--not high pitched. does not happen if i walk the bike, only when it is weighted, and it does not matter if i pedal or not. nothing seems to hit anywhere. I don't know much about wheels--does not seem to be any port for grease, nor any obvious way to take the hub apart --anyone have any ideas?
    thanks,
    Aug 2001
    Quote Originally Posted by jimcav
    thanks,
    Try a little silicon lube where the axle exits the hub. Some hubs have a neoprene seal that dries out and makes that kind of noise.
    Jun 2003
    awesome thanks
    Quote Originally Posted by Spoke Wrench
    is this silicone lube somehting i can get at a home depot place, or do i need to go to perfomance bike?
    Mar 2004
    Question Squeaky Spokes?
    If your axle doesn't turn out to be the culprit, then sometimes the spokes make that same sound. I don't know if your wheelset has spokes or not , but a little oil to each spoke head will quiet the sound.
    Feb 2002
    MIght be where the spokes cross
    If it happens once per revolution, then it is not likely the spoke crossings. But if it happens continuously, then a drop of lube at each spoke cross might fix it.
  1. Can I use a 27 rear cog with short cage DuraAce ?
    By scopestuff2 in forum Components, Wrenching
    Last Post: 09-16-2004, 05:27 PM
  2. Does 1 lb of fat = 1 lb of frame?
    By Bacco in forum General Cycling Discussion
    Last Post: 08-03-2004, 09:21 PM
  3. Can Shimano wireless Flight Deck be used with rear wheel?
    By Larry Klassen in forum Components, Wrenching
    Last Post: 07-04-2004, 09:07 AM
  4. Vento re-lacing complete! Track wheel now!
    By Qubeley in forum Fixed/Single Speed
    Last Post: 02-23-2004, 09:28 AM
  5. tolerances of rear wheel dishing
    By weltyed in forum Components, Wrenching
    Last Post: 02-07-2004, 06:42 PM
