Need Pump to replace Topeak Joe Blow II - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
  1. #26
    wut?
    Reputation: Clipped_in's Avatar
    May 2011
    Quote Originally Posted by jfaas View Post
    ...then bought a lezyne classic floor drive. I use them both, but I favor the lezyne for the chuck. It threads on to the valve so there is no chance it will fall off.
    I have been using a Lezyne Steel Drive for about 7 years and it has been flawless. I agree about the threaded chuck being very reliable.
    There I was...
  2. #27
    May 2012
    Quote Originally Posted by Clipped_in View Post
    how does that work? instead of a "QR" type of lock onto the presta valve, with the Lezyne, you screw it in?
  3. #28
    Reputation: nova_rider's Avatar
    Sep 2005
    Quote Originally Posted by sramred View Post
    Yes, older Lezyne floor and most of their hand pumps are simply screw-on. The problem I find is that they tend to pull out the valve core during removal, very frustrating when you are on the road trying to fix a flat, or simply top off. Not a fan with this design at all. Maybe this is why they now use a new design that does not screw-on, but uses a sleeve that locks onto the stem. It works better than the screw-on type, but I had the o-ring behind the lock sleeve slip out and cause leaks.
  1. Joe! Joe, Joe, Joe! Joe, Joe, Joooooooooooe!
    By JoeDaddio in forum The Lounge
    Last Post: 08-31-2019, 08:47 PM
  2. Topeak Joe Blow Pro Floor Pump
    By Jay Strongbow in forum General Cycling Discussion
    Last Post: 04-12-2017, 03:55 AM
  3. Topeak Joe Blow Pump Leaking?
    By hawker12 in forum General Cycling Discussion
    Last Post: 04-30-2016, 07:33 AM
  4. Topeak Joe Blow Mountain pump and road tires...
    By joshmv in forum Components, Wrenching
    Last Post: 04-20-2013, 05:35 AM
  5. Do I need the Topeak rack for a Topeak trunk?
    By rcook in forum Commuting, Touring and Ride Reports
    Last Post: 08-09-2011, 03:56 PM
