New B/B For NOS Campagnolo C-Record Chainset
Results 1 to 7 of 7
    Reputation: DannyBoy's Avatar
    I've managed to source a near complete C-Record Groupo, all I need is a bottom bracket, but don't know what size etc I need, or what best type is.
    The frame that all this stuff is going on currently has a modern Campy Chorus b/b and the shell is English threaded. I think the spindle width for an older chainset like this needs to be 111mm?
    I'm not sure what the best way to go is - Phil Wood (not familair with how these are fitted - tools req etc). Some help would be appreciated.
    If you can e-mail me direct that'd be cool [email protected]
    Dan.
    Kant phuckin sphell
    Reputation: the bull's Avatar
    Jan 2003
    This place is good!
    They have alot of infor on the bb size you will need.
    www.bicycleclassics.com
    www.tomsgarageapex.com
    Honda Acura Service and Repair
    Aug 2003
    Quote Originally Posted by DannyBoy
    Dan.
    The C-Record crankset takes a 111 mm BB spindle, but the current 111 mm racing triple BB won't work. One spindle is symmetrical, one isn't, I forget which is which. It's the same as the current Record Pista BB. The Pista, which is not really suitable for road use was, until this year, the only current Campy BB that would work for C-Record, Croce D'Aune, Chorus, and Athena cranks. I saw on Branford Bike that there is now a road BB for these cranks. IIRC, it's Veloce level.
    Or, you can get the Phil Wood, and never buy another bottom bracket. Phil BBs are simply the best there is. There is a Phil Wood tool that goes with Phil's lockrings. Rumor has it that installation and fine-tuning of chainline is much easier with 2 tools.
    Get the Phil.
    --Shannon
    Reputation: boneman's Avatar
    Nov 2001
    Get the Phil
    I ran a C Record crank and Phil BB for years. Great combination. The Phil model you want is the BRS-10. You will also need a set of lockrings (English or Italian). You will only need one of the Phil tools. Having two tools doesn't make the adjustment any easier.
    You don't need to crank the rings on that hard as they provide Loctite for the rings. If you do jam them on too hard, you run the risk of binding the inside of the ring onto the flange of the BB cartridge body. Trust me, I've done just that. I'd lightly grease the body flanges on either side before the install.
    You can order direct from Phil. I did it from London and had the BB in 3 days. Their customer service, voice or email, is excellent and responsive.
    You still in Kiwi country or back in Blighty?
    Quote Originally Posted by tube_ee
    Get the Phil.
    --Shannon
    AJS
    AJS is offline
    Reputation: AJS's Avatar
    Aug 2003
    Question
    Next time, post this in the "Campagnolo" forum, doncha think? ;)
    Reputation: T-Doc's Avatar
    Apr 2002
    Ac-h
    Campy AC-H (Centaur) BB is 111mm symmetrical and works fine.
    Apr 2002
    PS- it only about $26
  1. Colnago 50th Anniversary
    By Aaron Kent in forum Colnago
    Last Post: 12-09-2013, 08:08 PM
  2. what the deal with campy cassettes?
    By tarwheel in forum General Cycling Discussion
    Last Post: 06-02-2004, 08:54 PM
  3. Campagnolo presents its first compact drivetrain
    By AJS in forum Components, Wrenching
    Last Post: 05-11-2004, 07:33 AM
  4. List what you've got
    By campagnolOCLV in forum Components, Wrenching
    Last Post: 05-05-2004, 12:47 AM
  5. Campagnolo In Japan
    By Gregory Taylor in forum General Cycling Discussion
    Last Post: 03-18-2004, 12:24 AM
