Nipple Driver Recommendation
Results 1 to 16 of 16
    Apr 2011
    I'm not sure it's just my bad luck or these things are made to be $#!t but I've gone through 2 new nipple drivers in a year. First was Birzman spoke nipple driver which worked well for 1 wheel build. Then this thing won't spin anymore due to some friction developed inside. I returned it for a refund.
    Then comes Park Tool spoke nipple driver at $3 more. It worked well for 2 wheels, then about half way through 3rd wheel building, the shaft fell out. It's not like I was using it as a chisel with hammer. WTF?
    Anyone with recommendation for a decent spoke nipple driver that lasts longer? Thanks in advance.
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    I have had the same one for thirty five years, silver aluminum handle. Forget the brand.
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by rideit View Post
    Maybe "Bicycle Research"?
    Too old to ride plastic
    Sep 2011
    I've been using the same Bicycle Research driver (long) for 27 years. Hundreds and hundreds of wheel builds.
    This tool is not designed to tighten spokes by the way, just to thread the nipples on far enough for the pin on the end to disengage the driver. If you're tightening spokes with the driver, the spokes are to short.
    Nov 2002
    Why not buy a special bit and use it with an electric screwdriver?
    'brifter' is a lame word.
    ^This^
    I work for some bike racers
    and a bunch of skateboards
    Feb 2005
    Interesting, who makes the 'special bit'?
    May 2012
    Unior among others.
    https://www.amazon.com/Unior-Speed-N...CD9?th=1&psc=1
    Sep 2011
    For me, I'm just not sure that would be any better than a regular old nipple driver.
    Now, get off my lawn.
    This is the one I've been using for about 10 years. Uses a piece of 2.0mm spoke.
    https://problemsolversbike.com/produ...driver_-_25272
    Apr 2011
    Quote Originally Posted by 202cycle View Post
    That's exactly what I used it for.
    Thanks for the suggestions.
    Apr 2011
    Bicycle Research nipple driver is really hard to find on the market.
    I fixed my Park Tool driver with couple of lock rings I bought from a local hardware store for 33 cents each.
    I happened to have lock ring pliers so I replaced the snapped washer shown in the picture of the first post with 2 lock rings (for double secure force) and now it's working again. I think it was a quality control issue with Park Tool because that brass sleeve may not have been fully seated inside which the teethed washer wasn't slid in sufficiently down the shaft and ended up popping out.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I have the Park Tool and never really liked it.
    What do I use? I took a regular straight head screwdriver to a grinder, ground the edges down so there is a point in the middle. Works best for me!
    Oh, ahem, shouldn't this thread be in Wheels & Tires?
    Apr 2011
    But the shaft doesn't spin.
    I thought it's part of wrenching...
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by bvber View Post
    Precisely. I tried the Park tool and personally, I don't like the spin. I prefer a straight shaft. I find I have better control.
    Well yes, technically true. I was just trying to beat CX to the punch.
    Nov 2002
    A good article on the subject and a great blog on wheel building https://www.wheelfanatyk.com/blog/wh...those-nipples/.
  1. DIY trying stand, dishing tool, and nipple driver
    By matfam in forum Wheels and Tires
    Last Post: 05-05-2014, 08:54 PM
  2. HED Belgium clincher nipple and spoke recommendation
    By dwl in forum Wheels and Tires
    Last Post: 08-03-2013, 03:53 PM
  3. Hero bus driver blocks hit and run driver
    By mtnroadie in forum General Cycling Discussion
    Last Post: 04-11-2012, 07:22 AM
  4. OBL's driver convicted for being....OBL's driver!
    By il sogno in forum Politics Only
    Last Post: 08-08-2008, 01:12 PM
  5. DWI driver hit by another DWI driver
    By bonkmiester in forum The Lounge
    Last Post: 07-16-2008, 09:36 AM
