O-Ring Lubricant?
Results 1 to 5 of 5
    Slowpoke
    Reputation: Carbonman's Avatar
    Jan 2006
    Question O-Ring Lubricant?
    I have a pair of Ritchey V4 Road pedals that work great except for one small thing: they are so light that they don't float to a heel-down position unless the inner bushing o-ring cover is popped off. I would like to grease the rubber o-ring to let it spin easier. Is silicone grease or spray suitable for this? Ritchey doesn't have an email address to take inquiries, so you fine folks are my only resort.
    I can't ask my LBS for a definitive answer because they don't handle this version. I had to import the pedals because the V4 Road isn't distributed in Canada.
    No team-cest unless 8+!
    Reputation: Cruzer2424's Avatar
    Feb 2005
    that would work. i would probably use triflow.
    Feb 2002
    Any grease
    Quote Originally Posted by Carbonman
    If Ritchey has done their work properly, the o-ring should be resistant to normal hydrocarbon grease, since it is in contact with them all the time. Therefore, any oil or grease should be OK. If you're concerned about it, silicone spray or silicone grease would most certainly not attack the o-ring.
    toomanybikes
    Guest
    I have to lube these stupid things every year on the pool equipment.
    FWIW I use silicone spray on the ones around the pool and it works fine.
    Kant phuckin sphell
    Reputation: the bull's Avatar
    Jan 2003
    Talking Your pool uses
    Quote Originally Posted by toomanybikes
    Ritchey V4 Road pedals?
